Toda or Jun?????
Old Dec 3, 2001 | 11:28 PM
BuddhaSiR's Avatar
Default Toda or Jun?????
Hey everybody. i am currently facing a fork in the road in my engine build up. Can't decide on what kind of cylinder head setup to go with. Toda setup with Spec C cams, valve springs, retainers, and valves. OR Goin with the JUN setup, OR goin Crower valve springs, retainers, and valves with CTR cams. What ever i choose this will be goin on a LS block fitted CTR pistons. i Need your help guys.
Old Dec 3, 2001 | 11:55 PM
AwwsChwA's Avatar
Default Re: Toda or Jun????? (BuddhaSiR)
If you have the money, go TODA, hands down. Don't go with spec-C though. the spec-C cams are not recommended for street driving. I emailed TODA with some questions a while back, that's how I know. Put it this way: even the spec-A cams make 15 more horsepower than Type-R cams at top end, and 10 horsepower more than Type-R cams at the midrange. The spec-B cams will be plenty for a street car.
Old Dec 4, 2001 | 12:03 AM
BuddhaSiR's Avatar
Default Re: Toda or Jun????? (AwwsChwA)
Your probably right about the Spec C cams. I'll probably just tear some stuff up. I haven't really decided on what i want yet. I'll consider Spec B. thanks for some input.
Old Dec 4, 2001 | 03:55 AM
Tbone's Avatar
You also need to think about valve to piston contact issues with that set up and the useable power range. You cant rev a ls bottom like a vtec bottom, which you will need to do with toda b,c cams. I would look into toda A or skunk cams with your set up.
Old Dec 4, 2001 | 06:18 AM
89HF's Avatar
New User
Mike at Naples Acura did a dyno test not too long ago that was very informative.I think a search would bring this thread up.
Old Dec 4, 2001 | 11:19 PM
BuddhaSiR's Avatar
Default Re: Toda or Jun????? (Tbone)
tbone
i've thought about the valve to piston clearance. thanks for asking. Like i said i havent really decided on what i want to go with. i'm just keeping my options open for the moment and what's the problem with revving an LS bottomend.
jserman
Aug 1, 2006 08:07 AM
Tech6023
Sep 12, 2005 02:38 PM
SPOON_FED_DC_2
Mar 25, 2005 04:59 PM
lcopas
12
Jun 26, 2003 10:54 AM
TEGPOWER44
Jul 7, 2002 12:03 PM
