84-87 crx carbureted. Do you have picture of carb hooked up to vacuum lines?
Does anyone have a few picture of their carb with the vacuum lines hooked up it would be greatly appreciated. I know about some trick of taking out most of the vaccum but im trying to pass smog in california. if i was to take out most of that stuff would it still pass? basically egr wont work if i take out all that stuff rite which would effect nox but it wont effect hc or co rite? so if i was to get a newer cat the 3way obd2 version would it be able to take care of the nox that it puts out without an eg-r? you think i can pass wihtou the vacuum or can you post picture of your stock setup im kinda in a pickle.
8487, 87, carb, carburated, carburator, carbureted, carburetor, crx, engine, lines, mods, picture, turbo, vac, vacume
