Want to Buy Want to Trade/Want to Buy
WTB: H22 obd 1 TPS
Old Aug 24, 2004 | 08:02 PM
EgSick's Avatar
Default WTB: H22 obd 1 TPS
i don't know if the TpS is universal kinda like the map sensor is but i need one for my car.
Throttle Position Sensor
ASAP
TIA
Old Aug 24, 2004 | 10:12 PM
Qfactor's Avatar
Default Re: WTB: H22 obd 1 TPS (EgSick)
check my sig.
Old Aug 25, 2004 | 08:36 PM
AutoWerks's Avatar
yes they are... just take it off your civic motor... throttle. drill or cut off the riviots on the civic. then cut the h22 one off and put the new one on the h22 and use screws with the same threads.
after to set it.. start the car whiel it is running. use a volt meter tap one end to ground and the positive lead to the center wire, which is usually a red color.
set it to see DC volts. move the tps around untill you see .45volts. then tighten screw and set it.
Old Aug 26, 2004 | 07:07 PM
EgSick's Avatar
Default Re: WTB: H22 obd 1 TPS (AutoWerks)
i could just take a h23 throttle body and put it on my h22 motor right?
instead of the cutting or drilling?
Old Aug 26, 2004 | 07:09 PM
95 integra's Avatar
ive got a h22a TB if you need it though.
92Lude94
Mar 31, 2010 03:51 PM
pizzle
Northwest (Sales)
Nov 15, 2007 11:15 AM
mikegeezy
Apr 2, 2006 10:08 AM
AmonDin
Jun 22, 2005 02:49 PM
ITR632
Nov 1, 2002 07:42 PM
