CEL Code 4... Not the Dist.
***Searched BTW
Hey guys I have an EF with a sohc zc...mpfi swap whatever.. when i got it the cel light was on and it is code 4 the crank sensor. So i replaced the dist. still have the light. I check the wires and they SEEM correct never did a mpfi swap so i just checked a website that had a how to and match the wires up. Everything looks ok. If the wires are fine and the dist. is fine what else can it be? Or does it have to be on or the other? TIA Shaun
dont have it
but i rechecked it according to a mpfi swap page online and the helms ecu wire diagram and everything LOOKED ok, i will go through it better when i take out the motor.
am i correct though its either the dist. or the wires right?
but i rechecked it according to a mpfi swap page online and the helms ecu wire diagram and everything LOOKED ok, i will go through it better when i take out the motor.am i correct though its either the dist. or the wires right?
U should check the grounds to the wire and the ECU. If those check fine, then its your distributor. I don't see why you would need to take out and rebuild the engine. SEems like more of a hassle. I am having the same exact problem.
-Jon
-Jon
drinks2k
May 10, 2007 10:15 PM
and it would be easier.. i think to check out the wires while its out.... although i would be able to test em
