Huge shop sale
Old Aug 24, 2004 | 07:14 PM
boosted hybrid's Avatar
Default Huge shop sale
In an effort to raise cash to fund my road race eg project I am cleaning out some parts around the shop, here goes:
Hondata s200b with datalogging and 3 step/launch control feature. Brand new, never used. Comes with the software CD, com cable, push button for setting rev limiter/vtec/3step, clutch switch for 3 step, Hondata s200b blue box, ribbon cable, ecu chipping kit. I can chip your existing ecu for no extra cost, or sell a socketed ecu for 100.00. I have converter harness as well for 100.00 if needed.
650.00 shipped.
Rocket motorsports m22 turbo camshafts. These are brand new, never used but are excellent cams for turbocharged application. Larger primary lobes for increased throttle response, and turbo friendly lift and duration for making big power. For b-series vtec heads. 500.00 + shipping.
*3bar and pigtail are sold*
RC 660cc low impedance injectors, brand new. 250.00
*Denso 720cc injectors are sold*
I have resistor packs if needed for the sets of injectors.
*GM boost solenoid and pigtail connector sold*
*Pocket programmer sold*
Apexi Power FC ecu, Apexi Hand held controller, Datalogit datalogging/editing software, usb to com cable, Datalogit communication box. Everything that you need to tune your own Power FC to its fullest potential. The Datalogit lets you expand the tuning capabilities of the Power FC box to its fullest potential. 800.00 for everything. I have a OBD-1 to OBD-2a converter harness so that OBD-1 equipped cars can run the Power FC system without any wiring issues for an extra 100.00.
Knocklink knock monitor. I have modified the knocklink to be a plug and play to the OEM knock sensor. Included is the Bosch knock sensor and plug if the OEM knock sensor is not present on the engine block. I have used this for 5 tuning appointments, so its virtually brand new. The unit has to be calibrated to the engine each time, so its a bit time consuming for me using it on a daily basis. Its perfect if you are installing it into your car permanetly. A/F gauges are good, but the ability to see if the engine is knocking is priceless. 150.00. *Pending sale to Bryson*
T3 inlet flanges for making your own turbo manifolds. These are mild steel 1/2" thick water cut. Will not distort, and perfect for welding to stainless for your homemade equal length manifolds. I have 20 of these bad boys. 10.00 a piece. *4 of these sold so far*
D-series head flanges for making your own turbo manifolds/headers. These are mild steel 1/2" thick water cut. I have 15 of these. 20.00 a piece. *2 of these sold so far*
OBD-1 p75 ecu, 5 spd. Virgin ecu. 150.00. I will chip for Hondata/Uberdata/Crome for an additional 25.00.
2004 CRV cylinder head complete. K24 cylinder head, complete with all valvetrain, cams, etc. Approximately 2-3k on the head. 400.00.
*AEM/GM boost solenoid/pigtail harness sold*
(2) USB to Com connectors. Perfect working order, good for those who need to datalog a com port with only USB ports on the their laptops. 10.00 each, or both for 20.00 shipped.
Extra long road racing short shifter, brand new. The shifter is weighted piece, extra long so that the shifter **** sits right next to the steering wheel. Allows for minimal reach changing gears, very comfortable to shift with. As seen on Mike01gsr's 500whp Integra! 100.00 shipped.
Tech edge v1.5 wideband. Used for 10-15 tuning appointments, in good working condition. I am selling because I have two other good working widebands at the shop, I dont need a 3rd one. The wideband comes with the NTK sensor, all neccessary cables. 250.00 shipped.
*Not pictured*
Hybrid racing K-series eg motor mount kit, brand new. 400.00.
Clutchmasters stage 5 clutch, brand new for b-series. 300.00
Modified by boosted hybrid at 6:00 PM 8/26/2004
Modified by boosted hybrid at 6:01 PM 8/26/2004
Modified by boosted hybrid at 9:18 AM 8/28/2004
Modified by boosted hybrid at 11:59 PM 8/28/2004
Old Aug 24, 2004 | 08:11 PM
braintree's Avatar
Default Re: Huge shop sale (boosted hybrid)
pm sent
Old Aug 24, 2004 | 08:30 PM
Tchleung's Avatar
PM sent
Old Aug 24, 2004 | 08:49 PM
Nikoli's Avatar
Default Re: (Tchleung)
pm'd
Old Aug 25, 2004 | 02:05 AM
SOHCrx's Avatar
Default Re: (Deckedlude)
PM'ed too!
Old Aug 25, 2004 | 04:42 AM
Default Re: (SOHCrx)
Pm'd you guys back. 3bar and pigtail are sold, tech edge wb and power fc are pending sale.
Old Aug 25, 2004 | 05:40 AM
Default Re: (boosted hybrid)
Pocket programmer sold.
Old Aug 25, 2004 | 09:20 AM
White Smoke's Avatar
i my honda
Global Mod
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted hybrid &raquo;</TD></TR><TR><TD CLASS="quote">
A/F gauges are good, but the ability to see if the engine is knocking is priceless. </TD></TR></TABLE>
BUMP
Old Aug 25, 2004 | 06:00 PM
Default Re: Huge shop sale (si2die4)
AEM boost solenoid/pigtail = SOLD
Old Aug 26, 2004 | 02:04 PM
Added a brand new Hondata s200b, Rocket motorsports cams and Tech edge wideband pics. TTT!
Old Aug 26, 2004 | 02:32 PM
jdm_kenji's Avatar
i like hondata, pm sent
Old Aug 26, 2004 | 06:10 PM
2turbohatches's Avatar
Default Re: (jdm_kenji)
good stuff
Old Aug 26, 2004 | 09:10 PM
Default Re: (2turbohatches)
Bump.
Old Aug 26, 2004 | 09:27 PM
TeStUdO's Avatar
How much power is that clutch good for?? is it a 6 puck and is it for hydraulic tranny???
Old Aug 26, 2004 | 09:45 PM
Default Re: (TeStUdO)
Its rated for 350 ft-lbs of torque, but i have done closer to 400 ft-lbs on a race car that used a stage 5 clutchmasters. 350ft-lbs will get you in the neighborhood of 500-600whp depending on how high you are revving the engine. The clutch is actually a 4 puck, unsprung disk. Its for hydro trannies.
Old Aug 27, 2004 | 04:53 AM
ttt
Old Aug 27, 2004 | 08:36 AM
Mikes01GSR's Avatar
BAM Bump!!!
Old Aug 27, 2004 | 09:25 AM
*Boostwerks*'s Avatar
Boosted...
Consider that Knock Link SOLD.
I just PM'd ya...
Old Aug 27, 2004 | 09:27 AM
SIXTYdashONE's Avatar
HT's Biggest Loser
Default Re: (Bryson)
ill see you sunday jeff. i have your money right hurrr..
Old Aug 28, 2004 | 05:06 AM
Bump.
Old Aug 28, 2004 | 05:13 PM
project dc2's Avatar
ill take two D series head flanges
Old Aug 28, 2004 | 08:00 PM
Default Re: Huge shop sale (project dc2)
Pm'd you about the head flanges.
Old Aug 28, 2004 | 09:02 PM
95gsrturbo's Avatar
so much nice stuff, so little cash-- if you are willing to negotiate on the wideband let me know.
Old Aug 29, 2004 | 05:10 AM
Default Re: Huge shop sale (95gsrturbo)
Sorry price is firm. The sensor alone costs around 150.00.
Old Aug 29, 2004 | 09:52 AM
alpha's Avatar
You have PM
gsrhb7
Jan 24, 2006 07:00 PM
djmatix
Sep 15, 2003 01:59 AM
djmatix
Aug 29, 2003 07:43 AM
djmatix
Aug 27, 2003 08:31 PM
