Has This Ever Happened to YOU???
Old Aug 24, 2004 | 06:13 PM
nikker's Avatar
Default Has This Ever Happened to YOU???
i got a 94 5speed and all of a sudden today my car would be reving up when i pushed the accelerator but the car would barely move.
it kept getting worse by the minute until i would be at 4-5000 rpm and goin 3mph in first gear. the car has 106k miles on it and has NEVER got a tranmission flush. Am i having this problem becuase of the tranny fluid or is there something wrong with my transmission?
pleeeeeeeeeeeeeas help me!
Old Aug 24, 2004 | 06:16 PM
sillyboi's Avatar
Default Re: Has This Ever Happened to YOU??? (nikker)
check ur fluids.. i might be wrong.. n again it might be the clutch going bad..
Old Aug 24, 2004 | 06:17 PM
shawn_crx's Avatar
probably check you fluid.
But you might need a new clutch or Axles. Clutch is the case most of the time for 5 sp.
Old Aug 24, 2004 | 06:19 PM
twkdCD595's Avatar
Default Re: Has This Ever Happened to YOU??? (shawn_crx)
you smoked the clutch... from what you describe
time for a new one.
Old Aug 24, 2004 | 06:21 PM
nikker's Avatar
somebody told me that my clutch is almost gone since " the clutch has no play"
the man told me that becuase u have to lift the clutch really high, almost all the way up, before the car starts moving forward.
one more thing.. after my car stoped moving i left it on the road... i came back to it about 2 hours later and i was able to drive it home and the problem wasnt as bad but the problem was still defitney there.
one more thing... a new cluth master cylinder and cluth slave cylinder was put in about 1 month ago. could i still need a new clutch?
Modified by nikker at 11:56 AM 8/25/2004
Old Aug 24, 2004 | 06:24 PM
twkdCD595's Avatar
yeah it will chatter and engage roughly at first, then it just goes to mush after a while and slips like hell... pretty much the phase your at now.
the pedal will feel shitty and stiff when letting out/ engaging it will be at the extreme top or bottom of the pedal throw.
Old Aug 24, 2004 | 07:31 PM
hatchinprogress's Avatar
Default Re: Has This Ever Happened to YOU??? (twkdCD595)
sorry but its the clutch
Old Aug 24, 2004 | 11:10 PM
SpeedFreak77's Avatar
Default Re: Has This Ever Happened to YOU??? (hatchinprogress)
I second that..or third or fourth, whatever. It's definately the clutch.
Old Aug 24, 2004 | 11:38 PM
hond77's Avatar
Default Re: Has This Ever Happened to YOU??? (SpeedFreak77)
Sounds like clutch too. check fliuds
Old Aug 25, 2004 | 07:38 AM
brads94accord's Avatar
sounds to me like your clutch is gone. have fun replacing it, its a bitch. took me and my buddy 12 hours to get the tranny back in and lined up right. if you have access to a lift definately use it.
molezy7
Sep 4, 2008 05:57 PM
Jon Like Wh0a
Jun 7, 2004 08:23 AM
bhang
Jun 19, 2002 12:32 PM
Powered by Honda
Apr 11, 2002 07:50 PM
