Im not getting spark..why??
Old Aug 24, 2004 | 06:02 PM
KiNG $h!t's Avatar
Default Im not getting spark..why??
Im not getting spark..why?? what are all the reasons i may not be getting spark?? I have a stock b16. I already checked the coil and ignitor. what else could it be?
Ricey McRicerton's Avatar
Default Re: Im not getting spark..why?? (this guy 2fast)
Work your way out....Ignitor/coil, dizzy, plug wires, plugs
Old Aug 24, 2004 | 06:17 PM
KiNG $h!t's Avatar
thats everything it could be?
Old Aug 24, 2004 | 06:22 PM
hatchling37's Avatar
rotor, bad dizzy, no battery
Old Aug 24, 2004 | 06:46 PM
KiNG $h!t's Avatar
rotor is fine and so is battery
Old Aug 24, 2004 | 06:54 PM
Bailhatch's Avatar
Default Re: (this guy 2fast)
is the ecu turning on? if all the normal dash lights don't come on with the key you might not be getting power to the ecu.
Old Aug 24, 2004 | 07:11 PM
KiNG $h!t's Avatar
all normal lights come on in the dash
Old Aug 24, 2004 | 07:15 PM
sammysnakes's Avatar
check your fuses + grounds.
aandDavidsaid's Avatar
this happen to me and it was a blown fuse so check that because this sounds the exact same
Old Aug 24, 2004 | 07:49 PM
KiNG $h!t's Avatar
checking fuses tomarrow. hope thats it. I have already checked all grounds and they are fine
Old Aug 25, 2004 | 12:24 PM
was it the fuse
Old Aug 25, 2004 | 03:55 PM
KiNG $h!t's Avatar
nope wasnt a fuse.
Old Aug 25, 2004 | 04:05 PM
donkiman's Avatar
check the actual plugs
Old Aug 25, 2004 | 04:54 PM
KiNG $h!t's Avatar
I tried it with brand new plugs and no spark.
Old Aug 25, 2004 | 07:42 PM
hondandy's Avatar
Maybe your timing belt broke
Happened to me and since the dizzy didn't spin....no spark
Old Aug 25, 2004 | 08:36 PM
KiNG $h!t's Avatar
Default Re: (hondandy)
no my timing belt did not break.
Old Aug 25, 2004 | 08:49 PM
Quik Chris's Avatar
Was there any redish brown dust in the distributor? It can also be when the bering inside the distributor goes bad, it typically kicks up that nasty dust into the cap. I'd try a new distributor.
Old Aug 25, 2004 | 09:28 PM
Default Re: (Quik Chris)
well if u do need new dizzy i got a brand new one for $100
Old Aug 25, 2004 | 11:25 PM
CRX_1.8T's Avatar
i know it sounds dumb, but check the wire infestation that is under your dash. my friend and i just dropped a motor in and somehow a wire under the dash was loose. wouldn't even run until we connected it...
Old Aug 26, 2004 | 11:14 AM
KiNG $h!t's Avatar
no dust or anything in the distributer. the distributer is fine. will check the wire transfer
carlos8
Apr 25, 2014 12:03 PM
cticknor666
Apr 26, 2009 11:27 AM
aaronhume
Mar 15, 2005 12:08 PM
billybob
20
Aug 29, 2004 07:02 AM
wanttorace
Oct 8, 2002 06:42 PM
