CRX B18C1 w/New Civic Si Tranny
Old Aug 24, 2004 | 01:53 PM
spcrxracer's Avatar
Default CRX B18C1 w/New Civic Si Tranny whqt clutch?
OK ive got a crx with a b18c1 motor and i am upgrading my tranny to the 99-00 civic si tranny. Do i need clutch and flywheel for the integra, or the civic??
Modified by spcrxracer at 5:08 PM 8/24/2004
Old Aug 24, 2004 | 02:13 PM
EL Vap133's Avatar
Default Re: CRX B18C1 w/New Civic Si Tranny whqt clutch? (spcrxracer)
What tranny did you have before?
Old Aug 24, 2004 | 02:15 PM
shocker's Avatar
any b-series clutch and flywheel should work with that setup
Old Aug 24, 2004 | 02:16 PM
EL Vap133's Avatar
Default Re: (shocker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shocker &raquo;</TD></TR><TR><TD CLASS="quote">any b-series clutch and flywheel should work with that setup</TD></TR></TABLE>
Not if it's from a 91 and under B-series cable tranny.
Old Aug 24, 2004 | 02:17 PM
shocker's Avatar
true,i did forget to include that one
Old Aug 24, 2004 | 02:21 PM
spcrxracer's Avatar
i have a jdm b16 y1 non lsd tranny currentyl w/ shot synchros
Old Aug 24, 2004 | 03:37 PM
Change's Avatar
Default Re: (spcrxracer)
if i were to put a jdm b16a1 with an lsd cable tranny into an lx, what would i use? summit is a little un-clear in their adds...
Old Aug 24, 2004 | 04:42 PM
BR's Avatar
BR
Default Re: (pSI civic)
All 88-91 b-series clutch disks are the same.
All 92+ b-series clutch disks are the same.
All 88+ b-series pressure plates are the same.
All b-series engines use the same flywheel.
That should pretty much cover what you need to know.
Later,
BR
Old Aug 24, 2004 | 04:47 PM
EL Vap133's Avatar
Default Re: (BR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BR &raquo;</TD></TR><TR><TD CLASS="quote">All 88-91 b-series clutch disks are the same.
Later,
BR</TD></TR></TABLE>
You forgot the throw out bearing. If you go Hydro, you need a 92+ throw out bearing.
toolbox21
Oct 21, 2009 03:24 PM
meagainsttheworld
May 8, 2007 05:58 PM
Tru_Shine
19
Mar 4, 2006 01:08 PM
dEd hOm E
May 16, 2005 10:07 PM
turbo_ef9
Sep 4, 2004 07:58 PM
