d15b2 Engine Replacement How-to?????
Old Aug 24, 2004 | 10:28 AM
dbailey's Avatar
Default d15b2 Engine Replacement How-to?????
I'm getting ready to replace my weenie d15b2 stock engine with one of those JDM replacements where you have to transfer your intake, alternator, distributor, etc and was wondering if there are any step-by-step how-to instructions on pulling it off. I've NEVER pulled an engine but feel confident I could do it with the right set of how-tos. Mine is a 1990 Civic LX 4 door sedan. Any guidance would be greatly appreciated. Thanks guys!
Old Aug 24, 2004 | 10:32 AM
LSVTEC 91 Civic's Avatar
Banned
Default Re: d15b2 Engine Replacement How-to????? (dbailey)
What are you replacing your D15B2 with? And why do you want to transfer the DPFI intake anyway?
Old Aug 24, 2004 | 10:38 AM
dbailey's Avatar
Default Re: d15b2 Engine Replacement How-to????? (LSVTEC 91 Civic)
I'm replacing it with another d15b2 that is the JDM (Japan type) motor. They only put carbs on them over there supposedly so you have to flip the injection system over to them.
Old Aug 24, 2004 | 11:13 AM
EJ2-Fluffy's Avatar
If your talking about the D15 Vtec - then your gonna have to go MPFI lol.
-Jon
Old Aug 24, 2004 | 11:34 AM
dbailey's Avatar
Default Re: d15b2 Engine Replacement How-to????? (CRX-Fluffy)
No it's just the stock d15b2 that came in the sedans stock from the factory.
Old Aug 24, 2004 | 11:59 AM
Mr_CRX's Avatar
It's not really that hard, but since its your first time, just plan for taking a LONG time. I replaced my d15b2 a few months after I got my car with another d15b2 just to get around. I was 16 at the time and I probably took like a week to do it. I just labeled all the hoses and wires as i disconnected them off the engine in the car, then found that spot on the new engine and labeled those plugs/etc.
I just used a piece of tape with a number on it.
I know that's not a step-by-step, but hopefully it'll help you out a bit. It's definitely not hard at all, just time consuming. It may get frustrating at times, but after you're finished, you'll feel like you learned and accomplished a lot. I knew where every plug, hose, and wire went on that engine by the time I finished.
Good luck, and for wanting to do things on your own.
Old Aug 24, 2004 | 12:00 PM
crexer's Avatar
not sure what your talking about and why you would want a carbed' motor but why dont u just get the d15b Vtec motor? either way your gona have to convert to MPFI
Old Aug 24, 2004 | 12:04 PM
Mr_CRX's Avatar
Default Re: d15b2 Engine Replacement How-to????? (crexer)
This is how I understand it:
He has a d15b2 in his car, and he bought a JDM d15b2 to replace it (but the JDM one he got is carb'd), so he wants to switch his IM and everything over to the new one so it'll drop right in. He doesnt have to convert to MPFI if he just swaps his original IM over to the new engine.
Old Aug 24, 2004 | 12:08 PM
dbailey's Avatar
Default Re: d15b2 Engine Replacement How-to????? (Mr_CRX)
Yeap that's it exactly. The JDM engines only come carb'd. Single and dual. The intake manifold, alternator, distributor, etc stuff has to be flipped over to make it work. It is for my 15 year old as his first car. I was going to do a VTEC but figured due to money and power that maybe I ought to just put a fresh stock motor in it for now. I'm getting the engine for $550 shipped with a 6 month warranty.
Old Aug 24, 2004 | 12:13 PM
Mr_CRX's Avatar
Does that price include the transmision too? That seems a little steep.
I got my d15b2 for 200 bucks, and now I can't even sell it for 50
That's cool that you're doing that for your son though. My dad helped me put my first engine in too.
What exactly is wrong with the d15b2 thats in there right now?
EP3_05's Avatar
Ok pick up a helms manual. http://www.helminc.com Best money I have ever spent. Like the other guy said start labeling stuff if it is your first swap then it will be really easy to put the new d15b2 in. I would suggest swapping all the parts from the old motor to the new one while they are both out of the car as it should be alot easier with more room to swap the parts. Otherwise just follow the manual and make sure you take your time. Air tools are nice but not neccessary. I did my b16a swap into my 4dr without any air tools.
Old Aug 24, 2004 | 03:46 PM
dbailey's Avatar
Thanks for all the good ideas and suggestions guys! The $550 doesn't include the transmission and it all depends on what it came out of in Japan as to what components are on it plus they do not guarantee that they'll work since the Japan specs are different than the US models. Has anybody ever bought one of those JDM engines and swapped their components over with little hassle?
Old Aug 24, 2004 | 04:23 PM
Banned
You can buy a Complete JDM D15B VTEC with engine/tranny/ECU/harness for about the same price you bought the carb'd D15 for.
Old Aug 25, 2004 | 03:42 AM
dbailey's Avatar
No way! Where?
Old Aug 25, 2004 | 03:54 AM
Banned
http://www.japandomesticmotor....id=18
I know you can find them cheaper other places... but well worth it to me to spend a little extra for a complete swap.
Old Aug 25, 2004 | 07:24 AM
dbailey's Avatar
Hmmmm. I sent them an email asking if they provide EVERYTHING needed to make the swap work. Has anyone ever used JDM and have a success or nightmare story to tell about them? I'm alittle concerned about them only providing a 30 day warranty. There is no way I could get it installed and running in less than that and if it blows up I'm screwed! Thanks for the insight dude!
Old Aug 25, 2004 | 08:02 AM
Banned
Theres more companies around that deal with just swaps, thats the one that I found in 5 minutes.
Old Aug 25, 2004 | 08:48 AM
tilt's Avatar
here's the online helms for the crx. the process is going to be very similar to your car. fyi, the crx dx also has the same d15b2.
http://www.binghamtonlife.com/manual/2gsm/
Old Aug 25, 2004 | 09:08 AM
dbailey's Avatar
Default Re: d15b2 Engine Replacement How-to????? (tilt)
Dude! Thanks a million for the site! I'll print it all off and hopefully it'll keep me from totally screwing it up.
Old Aug 25, 2004 | 09:19 AM
Banned
https://honda-tech.com/zerothread?id=963657
Old Aug 25, 2004 | 10:28 AM
dbailey's Avatar
Thanks big man!!!!!!
ricardotorres87
Jun 27, 2016 10:27 AM
Hondadude65
Mar 13, 2015 12:14 AM
717DC
Nov 20, 2009 06:34 PM
DeadLeg
Oct 19, 2003 09:54 PM
