H23 swap questions
I tried searching but haven't found what I'm looking for. I've got an awesome deal working on an H23 to swap into my '93 S (yep, F22.) This is coming out of a '94 that was swapped for an H22. What I'm wondering is if I will need new axles, ECU, dist., etc. This is only a long block and I just want to know for sure what I'm gonna need to get this thing in easily.
Thanks in advance for any help you guys can offer.
Modified by mullet6577 at 7:08 PM 8/24/2004
Modified by mullet6577 at 7:17 PM 8/24/2004
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mullet6577 »</TD></TR><TR><TD CLASS="quote">I tried searching but haven't found what I'm looking for. I've got an awesome deal working on an H23 to swap into my '93 S (yep, F22.) This is coming out of a '94 that was swapped for an H22. What I'm wondering is if I will need new axles, ECU, dist., etc. This is only a long block and I just want to know for sure what I'm gonna need to get this thing in easily.
I know you will need an H23 ECU and wires run for the knock sensor on the H23 from the ECU. Not sure if the distributor works. Axles should be the same too.
3.point.2
10
Jul 12, 2004 07:20 PM
