headlight sanding/clearing
Old Aug 24, 2004 | 08:58 AM
b18c1eg2's Avatar
Default headlight sanding/clearing
Hi I was wondering if anyone know where i can i find a how to on clearing out the headlights making the lens clear gettin rid of the grits that come on headlights there was a how-to a while ago on how but i can t seem too find it be greatful if someone can post the link in here if found
thanks
Old Aug 24, 2004 | 10:01 AM
Mike813's Avatar
Default Re: headlight sanding/clearing (b18c1eg2)
you can use any glass/plastic compound and sand with super fine sand paper (forgot the #) repeat steps if needed...
Old Oct 4, 2004 | 10:36 AM
GSRBoy's Avatar
Default Re: headlight sanding/clearing (Mike813)
Use 1500 grit sand paper.
Old Oct 4, 2004 | 06:01 PM
rudeman85's Avatar
Default Re: headlight sanding/clearing (GSRBoy)
wow, 1500, my rear end isn't even that smooth
Old Oct 4, 2004 | 06:29 PM
sillyboi's Avatar
Default Re: headlight sanding/clearing (rudeman85)
or u can buy any plastic polisher.. you can find them at pep boys or autozone, use a dry towel, and start rubbing the headlight, then wipe it off with another dry towel, theres couple of threads here that shows you how to clean up your headlights,
Old Oct 5, 2004 | 03:39 PM
darkslide_77's Avatar
got a buffing pad that you've used......try buffing the headlights with that....will take that pale yellow discoloration right off
Roybal 3
Aug 18, 2008 12:37 PM
es_squared
Aug 11, 2008 01:19 PM
97BB6Type-SH
Aug 31, 2006 09:54 AM
xcom
Mar 2, 2004 09:00 AM
10K2HVN
May 21, 2003 10:23 PM
