ECU codes on an ef with b16a
Old Aug 24, 2004 | 06:55 AM
raymas8's Avatar
Default ECU codes on an ef with b16a
how do you check for ecu codes on a 89 hatch with a b16a ecu.. like where is the plug that you put a wire into so the check engine light blinks out a code?
Old Aug 24, 2004 | 06:58 AM
Die-Laughing's Avatar
Default Re: ECU codes on an ef with b16a (raymas8)
you just check the light on the ecu. if its not blinking then there is no codes.
Old Aug 24, 2004 | 07:00 AM
raymas8's Avatar
Default Re: ECU codes on an ef with b16a (Die-Laughing)
the b16 ecu does not have the led light like the stock ef ecu..
Old Aug 24, 2004 | 07:08 AM
slowpokesi's Avatar
yes it does, pr3 and pw0 both have the flashing led light.
What specific ecu are you using
Old Aug 24, 2004 | 07:16 AM
raymas8's Avatar
Default Re: ECU codes on an ef with b16a (slowpokesi)
i have the pr3.. i remember not seeing the light thou.. maybe is it at a different spot then the stock ecu? cuz i know there is no light where the window lines up
Old Aug 24, 2004 | 07:21 AM
slowpokesi's Avatar
pull the cover off thats over the ecu, the jdm ecu has the light in a diffrent spot, and you cant look at it with the cover on, unless you drill a hole in the cover over where the light is.
Old Aug 24, 2004 | 07:25 AM
raymas8's Avatar
thanks a lot i'm gunna go look for it once im done with school.. but thanks for the quick replies
Old Aug 24, 2004 | 07:47 AM
slowpokesi's Avatar
no problem
Old Aug 24, 2004 | 08:22 AM
Reelizmpro's Avatar
I had the EXACT same issue with my newly acquired CRX. Remove the cover...the light will be on the bottom as if the cover or ECU was upside down.
jfields06
Dec 27, 2008 06:42 AM
1320king
Jul 22, 2007 12:32 PM
drew2
Dec 3, 2005 11:51 AM
naptownrex
10
Apr 18, 2005 08:26 PM
hybridb18
Mar 29, 2003 09:12 PM
