mini me missing/struggling after 6k
Old Aug 24, 2004 | 06:33 AM
Layziebtnh055's Avatar
Default mini me missing/struggling after 6k
when ever i hit 6k in any gear it feels like the car is bogging or missing, i also am running lean, i have platmun spark plugs, ive searched and i think i need colder plugs or somthing, can anybody help me out thanks
Old Aug 24, 2004 | 07:05 AM
d357r0y's Avatar
Default Re: mini me missing/struggling after 6k (Layziebtnh055)
Make sure your timing is set, you will need an adjustable cam gear in order to make sure your cam timing is set to your ignition timing. (when you put on the cam gear, it will force you to rotate the cam 1/2 tooth to make everything line up).
a range colder plugs wouldn't hurt either.
Old Aug 24, 2004 | 07:38 AM
4drEF's Avatar
Keyboard Humorist
I would get rid of those plugs and use some regular copper NGK's. If you compare the metal that provides the spark, the platinum ones hardly have any metal. They always seem like a weak spark to me when I have used them.
If you are running lean, then maybe you are running out of fuel at the higher rpm. Fix that. Check your fuel pressure. Check your timing.
If you used a Z6 head then your timing is off by 1/2 a tooth like d357r0y stated. Cam gear.
Old Aug 24, 2004 | 07:59 AM
Default Re: mini me missing/struggling after 6k (4drEF)
i have a adjustable cam gear, its set to 5 degrees retarded, how do i know if the plugs are colder
Old Aug 24, 2004 | 08:32 AM
d357r0y's Avatar
1. set the gear to 0°
2. set your ignition timing to stock.
3. go to the local parts house and ask them to look up the spark plugs for the head you have.
4. ask for 1 heat range cooler (and get the copper like 4drEF suggests, they put out a fatter/hotter spark). The cooler plug will help in preventing detonation.
Tubbers530
Apr 20, 2018 09:51 AM
SinglecamMitch
Jun 5, 2008 09:18 AM
xmb63
Mar 3, 2007 05:12 PM
JaiDM
14
Jan 6, 2003 04:58 PM
