car leans out under boost, need help!
Hallo,
i have a big problem, since a few days my car runs sometimes extremly lean under boost.
i made no setup changes before than phenomen appears.
i have the following symphtoms:
the mixture is fine under part throttle until 1000mbar (absolute pressure) (closed loop is turned off)
then the mixture begins to enrich to 13.5:1 (thats also ok) but when i reach 0,2-0,3 Bar of boost the car
leans out dramaticaly to high 14:1's and then there are two options.
When i stay on the throttle sometimes it enriches to 12.5:1 (which is ok) when it reaches full boost (0,6 Bar)
and in the other case (which appears not so often then the first one) it leans out more so i have to
lift off the throttle.
i rechecked the fuelmaps and the complete engine management minimum four times but i can't find any malefunction
i also don't have holes in my fuelmap, the map is very linear and smooth.
now my question: are there ANY possibilities that it is NOT an electronic problem? if yes, what can that be?
please help me, i have no ideas any more.
Greets
Malte.
Greets
Malte.
Hi,
i have an additional idea... could it be a broken fuel pressure regulator? (i use the stock one and it has allready 160.000 km)
Greets
Malte.
Greets
Malte.
Oh yes, the fuel filter is also a possibility, i think it was last changed about one or two years ago and the last 6 month the car stood in the garage.
maybe i change the fuel filter and if this has no effect, i try another fuel pressure regulator...
anyone with other things i can check?
i thought that my inline fuelpump has a problem and so blocks the fuel but i think thats not the problem because it makes noises like everytime so it works...
Greets
Malte.
Greets
Malte.
R6Elmo
Feb 16, 2004 03:50 PM
