Rev Hard Turbo kit B-series motors ! Bay Area *Pictures* CHEAP!
Stage: 2 NEW GEN
Use: Street/Track
Part #: RHSTGII
Boost Level: 7psi
Injector Size: Stock
Horsepower/Torque: +120 / 285 ft/lbs
Rev Hard Cast Iron Manifold
Rev Hard T3/T04E Hybrid Turbo(eff. to 450hp)
Silicone Hoses & Clamps
Steel Braided -3 Oil Line
35mm external wastegate (7psi)
Oil Return Line
Vortech Blow Off Valve
High Pressure Fuel Line
2.25" Aluminized Mandrel Bent Piping
High Pressure Silicon Hose
2.5" Downpipe
Necessary Vacuum Tee's
Check Valves
Necessary Vacuum Lines
THE ONLY THING MISSING IS A FUEL PUMP AND INTERCOOLER
ASKING 1,850obo used for about 1k - 2k miles seriously! perfect turbo no play
leave contact information in PM
Use: Street/Track
Part #: RHSTGII
Boost Level: 7psi
Oil Return Line
2.5" Downpipe
Check Valves
