Roller Rocker Cams from Crane for All Motor ?
Anybody have experience using Roller Rocker Special Custom Cams from Crane Cams ( The cams are being develop with Gary G and Stephan P ) for ALL MOTOR Honda B Series ? Because I see they have Very High Duration and Valve Lift for this Roller Rocker Custom Cams NOW
Or Do you know anyone who using this Cams and are in The Top Positions in All Motor Class ?
Please sharing the Experience especially for the Results at the Dyno and on the Track .
Thank you for any info .
GOD BLESS US
GOD BLESS US
if your serious about horsepower, its the only way to go!!!!! just built new engine with roller setup, and love them, couldnt tell you how much power I gained, because this was a new setup, and before I was runnign factory roker setups, have heard storys that people have gained, anywhere from 11to25hp, Im not going to stick the old cams back in to find out... Most of your serious racers are running rollers, big advantage over factory setups!!!
Thank you Sir ,
Which Roller Cams from CRANE CAMS are you using ?
Are you using the Special Order One and which one it is ?
Anybody else using this Roller Cams ?
Thank you for your sharing info .
GOD BLESS US
GOD BLESS US
This just like toda'ss vtec killer cams except it replaces hondas rocker pads with roller rockers. Great for drag not great for street. You will be on the huge lobe all the time. Go lock the pin into the middle rocker on your current engine and see how that thing idles. It won't be that pretty.
I already use the TODA VTEC Killer Cams but I need Cams with Higher performance than this TODA Cams so i think Roller Rocker Cams from Crane Cams will be the BEST ONE .
Any others know , who else using this Special Order Roler Rockers Cams from Crane Cams .
Thank you in advance .
GOD BLESS US
GOD BLESS US
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by anlia »</TD></TR><TR><TD CLASS="quote">Thank you Sir ,
GOD BLESS US</TD></TR></TABLE>
I am running the Ferrea setup. the cams are bult by crane for ferrea, to their specs, but the cam in my engine is a special spec cam, for my engine that Ferrea design...
I have a set of the crane roller cams, not shelf stock, let me tell you one thing, be very careful when adjusting the cam gears. If you have over sized valves you will only have a few degress of adjustment in the gears. Too much and your valves with touch, make sure you clay the piston and check piston to valve clearance as well as the amount of adjustment you have with the cam gears. But they're bad-***.....
Any Dyno or How many HP you can gain when switch from Conventional VTEC Cams to this Roller Rocker Cams ?
Why I'm asking so many times because I never know any TOP OF THE ALL MOTOR CARS / DRIVERS who using this Crane / Ferrea Roller Rocker Cams ( Other than Clay Sloan ) ? Anybody know any other who using this set up .
Thank you .
GOD BLESS US
Thank you .
GOD BLESS US
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by anlia »</TD></TR><TR><TD CLASS="quote">Any Dyno or How many HP you can gain when switch from Conventional VTEC Cams to this Roller Rocker Cams ?
Thank you .
you dont see any one running them cause they are junk. there arent enough cam profiles to try anything different. and its quite easy to break the rockers.
however in about 1-2 months phantom grip will be releasing some roker lockers that replace the outside rockers and keep the stok centers. this way you can still use any off the shelf cam. and it will be alot cheaper than rollers. they are being tryed and proven on many top race teams around the country.
Thank you .
we were the first all motor car to run that setup back in 2002. we fooled around with them for 5 events+ testing. on the 6th event we put some crower 403's and went .3 faster on the very first pass. when we pulled the rockers out 2 of them just plain fell apart. the cams were out of round and we wasted 3 heads. i from personal experience can say they are pure junk.
well I think this guy is a fool brauning papdakis me gardella on and on and on are using them without a problem maybe he had installation error or you were hitting your valves?
do bang something that has been proven time and time again
as far a crower goes I wouldn't put those china junk cores a mile from my car
ask anyone on here about crower cams breaking it isn't hard to find that out.
just my 2 cents
just my 2 cents
yeah there so good and worth every penny, thats why you are selling your set.
well im such a fool i couldnt figure out how to keep the greatest cams int the world from blowing heads up, but somehow ive managed to put about 50k on a set of original crower 403's and they are still going strong.
im definetly a fool. i only spent $550 for those crowers back in 2000. i spent about 2g's on the roller rocker setup, and only one set still works.
i cant wait to see you go through growing pains with your car. im going to keep walking over to your pit and call you a fool and ask if you know what you are doing. see ya at the track.
I sold an extra set I had for r and d testing before I bought a custom set I used that money to buy another car thanks
you seem to be the only one bashing them don't you ?
huh
huh
