SS Clutch Line
Old Aug 23, 2004 | 08:05 PM
Evs-One's Avatar
Solbros Owns Me
Default SS Clutch Line
Hey, I remember seeing one a while back, but does anyone know of a website that sells a stainless braided clutch line for EG or Integra?
Old Aug 23, 2004 | 08:16 PM
MAD ITR 55's Avatar
Default Re: SS Clutch Line (Emerika)
I think inlinefour.com has them.
Old Aug 23, 2004 | 08:18 PM
KOALA YUMMIES's Avatar
Default Re: SS Clutch Line (MAD ITR 55)
Yep
http://www.inlinefour.com/il4perclutli.html
Old Aug 23, 2004 | 08:20 PM
MAD ITR 55's Avatar
Default Re: SS Clutch Line (KOALA YUMMIES)
I thought I remembered seeing them awhile back
Old Aug 23, 2004 | 08:44 PM
integrasi's Avatar
does any1 make full clutch line?? mine tended to leak where it bolts.
Old Aug 23, 2004 | 08:46 PM
esponet's Avatar
i4 sells them, the spoon one are for rhd cars, fittings are different. (just incase you run across the spoon one)
Old Aug 23, 2004 | 08:50 PM
SuzukaBlueAP2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MAD ITR 55 &raquo;</TD></TR><TR><TD CLASS="quote">I think inlinefour.com has them.</TD></TR></TABLE>
I used theirs
Old Aug 23, 2004 | 09:12 PM
integrasi's Avatar
Default Re: (esponet)
never knew spoon makes clutch line
Old Aug 23, 2004 | 09:14 PM
esponet's Avatar
Default Re: (integrasi)
they do, but willnot fit usdm cars.
Old Aug 23, 2004 | 09:18 PM
rodimus's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by esponet &raquo;</TD></TR><TR><TD CLASS="quote">they do, but willnot fit usdm cars. </TD></TR></TABLE>
yep. inlinefour has them..
but also marcus at http://www.heeltoeauto.com/ (he's a sponsor on here)
carries them. that's where i got mines from
edit: fixed link
Modified by EVOL at 5:16 AM 8/25/2004
Old Aug 24, 2004 | 08:19 AM
Stinkycheezmonky's Avatar
Suspetise...
Default Re: (EVOL)
What exactly would this benefit?
Old Aug 24, 2004 | 08:20 AM
integrasi's Avatar
Default Re: (sscguy)
look
Old Aug 24, 2004 | 08:22 AM
Philly_NBP_R's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sscguy &raquo;</TD></TR><TR><TD CLASS="quote">What exactly would this benefit?</TD></TR></TABLE>
"The il4 clutch line was designed with racing technology and the data acquired throughout our years of expierence. When you replace your factory "rubber" clutch line with one of our il4 clutch lines, you will reduce volumetric expansion by over 70%. With this improvement, you will notice that your clutch engagement and disengagement is faster, consisent and more accurate, thus improving overall performance and consistency."
follow the link buddy...
Old Aug 24, 2004 | 08:24 AM
Hybrid ctr's Avatar
Default Re: (Philly_NBP_R)
Fastline Performance makes SS clutch lines
http://www.fastlineperformance.com/clutchline.htm
Old Aug 24, 2004 | 08:41 AM
esponet's Avatar
mine leaked,and its either wait 2 months for a new one, 1 day for a used one, or 2 weeks for a spoon one. so i choose the 2 weeks. (btw rhd car so i can't use usdm oem) but i did noticed a bit of difference, could be the line or the new clutch i put in.
Old Aug 24, 2004 | 09:04 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Philly_NBP_R &raquo;</TD></TR><TR><TD CLASS="quote">
follow the link buddy... </TD></TR></TABLE>
Old Aug 24, 2004 | 09:05 AM
ek four's Avatar
i have a used one from Fastline Performance... still in perfect condition... let me know if u want it.. off my 98 itr
Old Aug 24, 2004 | 11:39 AM
RaVAGE00's Avatar
New User
Default Re: (ek four)
Is this an easy install? Will I need to bleed the clutch line?
Old Aug 24, 2004 | 11:57 AM
esponet's Avatar
Default Re: (RaVAGE00)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RaVAGE00 &raquo;</TD></TR><TR><TD CLASS="quote">Is this an easy install? Will I need to bleed the clutch line?</TD></TR></TABLE>yes its easy install, yes you will have to bleed the lines
Old Aug 24, 2004 | 12:15 PM
NAstreetEH2
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek four &raquo;</TD></TR><TR><TD CLASS="quote">i have a used one from Fastline Performance... still in perfect condition... let me know if u want it.. off my 98 itr </TD></TR></TABLE>
how much do you want?
Old Aug 24, 2004 | 12:56 PM
Maximus's Avatar
Default Re: SS Clutch Line (integrasi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integrasi &raquo;</TD></TR><TR><TD CLASS="quote">does any1 make full clutch line?? mine tended to leak where it bolts.</TD></TR></TABLE>
JDM_Jon can hook you up with a full SS clutch line. Not just a 6 inch piece but the whole shibang. DOHC Garage!
Old Aug 24, 2004 | 01:29 PM
mine leaked,and its either wait 2 months for a new one, 1 day for a used one, or 2 weeks for a spoon one. so i choose the 2 weeks. (btw rhd car so i can't use usdm oem) but i did noticed a bit of difference, could be the line or the new clutch i put in.</TD></TR></TABLE>
How is the clutch line from the unibody hardlines to the transmission hardlines different? The slave cylinder is in the same location and people use the same lines for JDM swaps all the time. Just curious...
Old Aug 24, 2004 | 01:47 PM
Suspetise...
Default Re: (KOALA YUMMIES)
Right, so I like being spoon-fed info I don't bother looking up Beyond that, I understand if you have a leaky clutch line and need replacement, but clutch feel/precision/engagement speed? Sounds like a load of BS to me. I can't imagine the clutch could engage much faster with that line than if you just plain dropped it, and I would imagine that the feel would depend more on the pressure plate resistance.
Old Aug 24, 2004 | 01:56 PM
BudMan's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sscguy &raquo;</TD></TR><TR><TD CLASS="quote">Right, so I like being spoon-fed info I don't bother looking up Beyond that, I understand if you have a leaky clutch line and need replacement, but clutch feel/precision/engagement speed? Sounds like a load of BS to me. I can't imagine the clutch could engage much faster with that line than if you just plain dropped it, and I would imagine that the feel would depend more on the pressure plate resistance.</TD></TR></TABLE>
I agree to a point, because the line is short...then again, you can feel the difference when switching to ss brake lines. I just ordered one of these since I have to work on the tranny anyway.
Old Aug 24, 2004 | 03:19 PM
esponet's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KOALA YUMMIES &raquo;</TD></TR><TR><TD CLASS="quote">
How is the clutch line from the unibody hardlines to the transmission hardlines different? The slave cylinder is in the same location and people use the same lines for JDM swaps all the time. Just curious...</TD></TR></TABLE>
the slave end is d same,but the one from the chasis is diferent size fittings.
