CAR WON'T HEAT
Ok I have a new radiator, and new hearter core. and changed all the radiator fluid. But my car still won't heat. Does anyone have any ideas, should I change my head gasket? Please help me out.
Sounds like a problem with the cable running from the hot/cold dial in the climate control. Can you feel the tension of the cable when you twist it over to hot or does it just feel like the **** rotates easily without any resistance? You can open up the channel or whatever you wanna call it to the heater core manually if you can't fix the cable. Its on the firewall kinda behind the throttle body. good luck.
there is also a lever under the dash behind the passenger side of the center console that will open the heat side of your ventilation system. If your talking about your cars engine temp. not heating up you might not have a thermostat or its stuck open.
