Any easy practical mods to do on a 94 wagon?
My sister has a 94 wagon with 150k miles. Runs great, rusted doglegs, but thats the only issue.
Are there any good practical mods or generally known things to do to improve this car? She isn't looking for more power or anything.
Also I have heard removing the plastic from the rear wheel wells helps drain the water and prevent 1/4 panel rust
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by riceburner247 »</TD></TR><TR><TD CLASS="quote">I'd say work on the suspension. Find her a good quality strut/spring combo.
indeed...even a slow car can be fun in the twisties as long as you have the right suspension set up....take my car for example, took it out for a drive the other day and it was quite fun... never sped over the speed limit and still had lots of fun... its a perfect road too... it begins with a sign that shows a REALLY curvey road and then below it it says "next 3 1/2 miles"....heaven
</TD></TR></TABLE>indeed...even a slow car can be fun in the twisties as long as you have the right suspension set up....take my car for example, took it out for a drive the other day and it was quite fun... never sped over the speed limit and still had lots of fun... its a perfect road too... it begins with a sign that shows a REALLY curvey road and then below it it says "next 3 1/2 miles"....heaven
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 28 »</TD></TR><TR><TD CLASS="quote">Also I have heard removing the plastic from the rear wheel wells helps drain the water and prevent 1/4 panel rust</TD></TR></TABLE>
it'll also allow for water to get splashed up inside your quarter panels, which will promote rust rather than prevent it...leave them where they are at...besides, if it's already rusting, removing them now won't really help anything...
as far as practical mods, a grounding kit, mild suspension upgrades (spring/shock/strut bars/sway bars/bushings <that's a biggy!) can all make the ride a little more enjoyable...
DG-FNR
10
Sep 7, 2008 06:14 PM
turnsignalandy
Feb 13, 2007 03:40 PM
EH..phantom
Mar 14, 2004 10:21 AM
