FS- B series Vtec distributor bodies, modded non-Vtec body
Old Aug 23, 2004 | 05:19 PM
Bnjmn's Avatar
Default FS- B series Vtec distributor bodies, modded non-Vtec body
(1) Vtec casing, with all sensors, wiring, OBD 2 connector- $25
(1) Vtec casing, missing some sensors, OBD 1 connector (cracked, but works fine)- $25
(1) non-Vtec casing, modified to work on a Vtec head, missing sensors, OBD2 conncector- $15
With these- you can swap the guts of a non-Vtec distributor in a Vtec dizzy body and save a bit of money.
Thanks
Ben
Old Sep 2, 2004 | 08:01 AM
Bnjmn's Avatar
Default Re: FS- B series Vtec distributor bodies, modded non-Vtec body (Bnjmn)
up.
Old Sep 5, 2004 | 06:42 PM
vtec181's Avatar
wat do you mean by the casing?..the actual metal body that bolts to the head? pics?
Old Sep 18, 2004 | 09:11 PM
Bnjmn's Avatar
Default Re: FS- B series Vtec distributor bodies, modded non-Vtec body (vtec181)
yes- the casing, that holds the sensors and the dizzy shaft. The insides are the same between all B series distributors, only the body of the distributor is different, to make room for the Vtec solenoid.
up......
Old Oct 1, 2004 | 06:05 AM
Bnjmn's Avatar
up...
markviiisvt4
Oct 17, 2007 08:08 AM
dapump2003
Jul 17, 2007 08:47 PM
Spence
Northwest (Sales)
Nov 29, 2005 08:17 PM
