N3wb question regarding SC'd S2000 with FMIC?
How does this work using an after cooler say on a Comptech SC? Is it just for bling? Or is there functionality with it? Q me in please
it depends on whether you use it.
if you just have it sitting there it is bling. if you do custom piping it is functional. A FMIC AND the aftercooler would make for some cool charge temps, but the longer piping means boost takes longer to build.
All those thoughts running through my head... how the hell would you make the aftercooler AND Front Mount work in sequence ginen the Comptech setup? They must be blingers with the FMIC's... more info
That why I posted this in teh S2000 forum... cuz none of the Boosted S2k guys hang out in the FI forum.... BUMP
Well see the air leaves the SC then goes to the front mount then into the watter to air after cooler then into the TB.
It works very well actually
I would like to see a pic of teh charge piping... The pics I saw with the FMIC and aftercooler had it showwing the SC hooked right up to the aftercooler... PICS!
jbell
Oct 24, 2006 09:18 PM
