what compression, and c-speed if not accurate.
Old Aug 23, 2004 | 04:25 PM
Fuzion's Avatar
Default what compression, and c-speed if not accurate.
my set-up
b18C block
jdm itr internals (full internals crank/rods/pistons)
b16 head (stock)
2 layer HG ( stock w/ middle layer removed).
just wanted to know what kinda compression number i should be looking at?
Old Aug 23, 2004 | 04:31 PM
Fuzion's Avatar
Default Re: what compression, and c-speed if not accurate. (Fuzion)
6 views and no response yet....help me Ht please
Old Aug 23, 2004 | 04:34 PM
LSVTEC 91 Civic's Avatar
Banned
http://technet.ff-squad.com/cr-calculator.htm
Old Aug 23, 2004 | 04:36 PM
jdmHboy's Avatar
11.7:1
Old Aug 23, 2004 | 04:59 PM
beaterdriver's Avatar
i got 11.26
Old Aug 23, 2004 | 05:12 PM
jdmHboy's Avatar
Default Re: (beaterdriver)
aahhh i think ur right i messed up
Old Aug 23, 2004 | 06:56 PM
Fuzion's Avatar
thank you guys for ur help
Old Aug 23, 2004 | 07:15 PM
seems to me like its basically an itr motor w/o the goodies in the itr head (i.e. cams, valvetrain, lma's,e ct.)
Old Aug 23, 2004 | 07:22 PM
Fuzion's Avatar
its got goodies thats goin in there, rocket cams and valvetrain the "small" ones........even thought all his cams are huge!!!!
Old Aug 23, 2004 | 07:54 PM
Evs-One's Avatar
Solbros Owns Me
Default Re: (Fuzion)
basically it's a jdm itr motor, with equivalent to .012" off the head, assuming you took the middle layer of the gasket out. so i'd say 11.3:1 give or take.
Old Aug 23, 2004 | 08:09 PM
Fuzion's Avatar
Default Re: (Emerika)
think it should run ok wit the small rocket cams or buddy club spec III plus cams shafts
Old Nov 2, 2004 | 02:10 PM
kidkombo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fuzion &raquo;</TD></TR><TR><TD CLASS="quote">my set-up
b18C block
b16 head (stock)
just wanted to know what kinda compression number i should be looking at?</TD></TR></TABLE>
its exactly like a type r motor minus the mild port...valves, rocker arms, etc...imagine putting a stock head gasket on that and a type r head youll have a type r motor.
Old Nov 3, 2004 | 04:36 PM
Default Re: what compression, and c-speed if not accurate. (kidkombo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kidkombo &raquo;</TD></TR><TR><TD CLASS="quote">its exactly like a type r motor minus the mild port...valves, rocker arms, etc...imagine putting a stock head gasket on that and a type r head youll have a type r motor.</TD></TR></TABLE>
i never even thought of that...
daym, i need to think when i read
Old Nov 3, 2004 | 05:19 PM
Victor Penner's Avatar
Default Re: what compression, and c-speed if not accurate. (beaterdriver)
JDM ITR pistons are slightly higher in compression than the USDM ones.
Victor Penner
kennie555
Feb 22, 2013 12:45 PM
nikanoras
Feb 16, 2010 10:26 PM
A2_8U
10
May 31, 2006 11:15 PM
Funnyclub
May 9, 2005 02:25 PM
smkngsr
Apr 28, 2005 12:28 PM
