Center console warm?
Old Aug 23, 2004 | 02:23 PM
RiCE On IcE 2's Avatar
Default Center console warm?
I got a new tranny and I noticed that wen I got my car back the center console on the right side would get warm as would the shift boot. Maybe i just never noticed before but i don't think it did that before. The right side of the console is noticeably warmer then the left side of the console, is this normaly or something else.
Old Aug 23, 2004 | 02:25 PM
Rguy's Avatar
Voted Best Looking GDD Poster
25 Year Member
Community Builder
Community Influencer
Active Streak: 60 Days
Normal.
Old Aug 23, 2004 | 02:26 PM
itralex's Avatar
Default Re: Center console warm? (RiCE On IcE 2)
the Exhaust is right under the centre console
Old Aug 23, 2004 | 02:29 PM
Mugen Mike's Avatar
Default Re: Center console warm? (HypeR1004)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HypeR1004 &raquo;</TD></TR><TR><TD CLASS="quote">the Exhaust is right under the centre console</TD></TR></TABLE>
Exactly, the gearbox is located in front of the passenger footwell. Unless of course, the car is an S2000?
Old Aug 23, 2004 | 02:31 PM
Default Re: Center console warm? (Mugen Mike)
yea but i never noticed this before so u guys have always had this? they didn't somehow take a heat plate off or something?
Old Aug 23, 2004 | 03:31 PM
len's Avatar
len
Check the rubber boot that seals the shifter. If it came loose, which can happen very easily, all the heat will come in from there. It is normal for it to be a little warm, but if it feels unusually warm, then I'd check that boot. Also, the rubber boot that seals the parking cables.
Old Aug 23, 2004 | 03:54 PM
Default Re: Center console warm? (len)
could that have come loose under regular shifting conditions? can that be checked from inside the cabin or have to get the car up to see?
Old Aug 27, 2004 | 10:27 PM
so can i see if the seal is bad within the cabin or do I have to jack the car up? The center console is definately warmer then it was before.
Old Aug 28, 2004 | 04:51 AM
01PYTypeR#1140's Avatar
From: Couple SW99 40 Cal. For Ya, Do Ya Really Want It.., NJ, U.S.A
Check to see if you still have a head shield on your cat.
Old Aug 28, 2004 | 04:55 AM
1GreyTeg's Avatar
Default Re: Center console warm? (01PYTypeR#1140)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 01PYTypeR#1140 &raquo;</TD></TR><TR><TD CLASS="quote">Check to see if you still have a head shield on your cat.</TD></TR></TABLE>
Heat shield?
For the life of me, I don't know why people don't spellcheck their posts Before.
At any rate depending on the outside temps it can still be hot regardless of the heatshield being there or not.
Old Aug 28, 2004 | 11:50 AM
len's Avatar
len
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RiCE On IcE 2 &raquo;</TD></TR><TR><TD CLASS="quote">could that have come loose under regular shifting conditions? can that be checked from inside the cabin or have to get the car up to see?
You may be able to access this boot by removing the center console assembly.
It is a rubber boot that is stretched to fit so the possibility of it coming off isn't impossible.
Old Aug 28, 2004 | 01:27 PM
Big Phat R's Avatar
Default Re: Center console warm? (1GreyTeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1GreyTeg &raquo;</TD></TR><TR><TD CLASS="quote">
Heat shield?
At any rate depending on the outside temps it can still be hot regardless of the heatshield being there or not.</TD></TR></TABLE>
No heat shield makes a huge difference.
It might be possible that they neglected to put it back on after the work on the tranny.
Old Aug 28, 2004 | 01:53 PM
1GreyTeg's Avatar
Default Re: Center console warm? (Big Phat R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Big Phat R &raquo;</TD></TR><TR><TD CLASS="quote">
It might be possible that they neglected to put it back on after the work on the tranny.</TD></TR></TABLE>
No heat shield made absolutely no difference on mine. Maybe I'm a minority but the center console got hot when it had all the shields in place and it gets just has hot now. Oh well.
Old Aug 28, 2004 | 03:30 PM
hadboosttroy's Avatar
you need to take your own advice . Although I admit spell check won't catch that
Old Aug 28, 2004 | 04:21 PM
Understeer's Avatar
Default Re: Center console warm? (hadboosttroy)
I bet you it's only warm there when the front windows are open. Even open a little bit, it will be warm. Close all windows, and see if it's NOT warm. I bet it won't be...
Old Aug 28, 2004 | 08:21 PM
R4ND0M's Avatar
Default Re: Center console warm? (Understeer)
I don't have an R, but down by the E-brake slit, I notice heat coming from there alot. Seems normal though.
Old Aug 30, 2004 | 08:23 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Understeer &raquo;</TD></TR><TR><TD CLASS="quote">I bet you it's only warm there when the front windows are open. Even open a little bit, it will be warm. Close all windows, and see if it's NOT warm. I bet it won't be...</TD></TR></TABLE>
whys that.. the heat tends to run through the center console and out the window?
Old Aug 30, 2004 | 12:27 PM
Dave-ROR's Avatar
Heat shield?
Anton: While I agree with you normally I must admit.
For the life of me, I don't know why spellcheck would have flagged the word "head" as it is a valid word in the english language.
Old Aug 30, 2004 | 12:36 PM
Footwork's Avatar
https://honda-tech.com/zerothread?id=226937
Old Aug 30, 2004 | 12:49 PM
Understeer's Avatar
I don't know why, but I've experimented this over and over again. Close the all windows, and the console will not be warm.
Old Aug 30, 2004 | 06:57 PM
Mythias's Avatar
I had the same problem with my 00 ITR... I did a search and found the answer.
Old Aug 30, 2004 | 07:00 PM
ITR640's Avatar
When ever I drive my car hard the shift boot area tends to increase in temperature. So this could be related. Have you been driving the car hard?
Old Aug 30, 2004 | 10:07 PM
Default Re: (01ITR640)
well i took apart the console and it seemed like the rubber boot was a off sorta.. it's not supposed to make a "glued" seal right just flex it back withing the circle?
SuperSi
Nov 10, 2021 02:04 AM
goldef
15
Aug 24, 2007 12:48 PM
besouza
15
Dec 5, 2005 09:08 AM
