ASAP: VAFC 2 help.. WIRING and color codes
Old Aug 23, 2004 | 02:05 PM
DarkBB4's Avatar
Default ASAP: VAFC 2 help.. WIRING and color codes
i have a 1995 prelude vtec and i just got a vafc 2
i removed teh ecu (footrest) panel and now i have no idea what to do
my question is ... How doi know which wire goes wehre, and what the color code's are for my ecu... I Have a chart (see below)
Ami going to use All three of the ECU wires,, ( and cut a few from each) OR one specific bundle of wires
HELP
Old Aug 23, 2004 | 02:11 PM
Behan's Avatar
Default Re: ASAP: VAFC 2 help.. WIRING and color codes (DarkspeedVtec95)
you will be using a few wires from each connector.
You are missing a very important set of instructions. There should also be a diagram with the ecu pinouts that correspond to the wires you need to splice into. The vafc 1's diagrams can be found on http://www.apexi.com but the vafc2's diagrams are not on the website.
I'm sure they are the same between the two versions, but i believe the vafc 2 has a few more wires that need to be spliced in. ( due to the added functions ) I'm not 100% sure about that though.
Old Aug 23, 2004 | 02:13 PM
DarkBB4's Avatar
Default Re: ASAP: VAFC 2 help.. WIRING and color codes (Behan)
i thought i was just tapping into the wires???
anyways.. does apexi.com hae the color codes?
i serisouly Dont knwo wher to gof rom wehre i am
im an idiot
sorry
Old Aug 23, 2004 | 02:18 PM
DarkBB4's Avatar
ok found it...
so the wires on here, are where i tap into, but on the b ack side ( the wire part)..... and thats IT??
Old Aug 23, 2004 | 02:31 PM
DarkBB4's Avatar
that diagram is messed up definently
is that diagram... suposed to be As if it were Plugged in ( so like reversed)
or is that supposed to be as if u were looking at it..........
anyoen know what c olor Honda's GROUND AND POWER lines are supposed to be..... could it be Yellow and BRown?... or Red w/ black stripe for power
im all confused
Old Aug 23, 2004 | 02:48 PM
Behan's Avatar
the three plugs are different sizes so it should be self explanatory which one to use.
I.E. vtec signal, IG power, etc. on this plug, VTM, etc. on tis plug.
As far as the location on the connector, the diagram is of the plug facing the ecu. You have to match the corresponding wire on the back side to the pinout.
Old Aug 23, 2004 | 03:14 PM
DarkBB4's Avatar
alright now, the guy who i bought the vafc 2 from .. didn't have a few wires connected...
The dark blue, the light blue and the orange.....
VTC cam signal
VTM signal and the TDC signal
Do i need these?
Old Aug 23, 2004 | 04:31 PM
DarkBB4's Avatar
anyone know
anyways: curently im jjst splicing the wires, and i will soon begin to sotter (SP) them.....
would it be ok to just sotter the power and the ground for the time being.. just so it lights up ( im excited to see it)?????
Old Aug 23, 2004 | 04:40 PM
Behan's Avatar
hook it up correctly and then you can play. Seriously i wouldn't **** with it until it is completely installed. I believe the instructions also say something to that effect.
BTW, yes you should hook up all the wires. I don't know how the other guy used it without VTC signal hooked up but you should definetly install all the wires.
Old Aug 23, 2004 | 06:02 PM
DarkBB4's Avatar
ok thanks, so for all the wires except the VTM (which i just cut away from the ecu, and just plug into the vafc)
do i just tap into the existing wires?
Old Aug 24, 2004 | 10:58 AM
DarkBB4's Avatar
ok, got it installed and it looks nice illl get pics soon
anywyas. the tihing has a passwordon it from the previous user.. how doi get it off?/ i tried takin off the battery terminals but nothin works
Old Aug 24, 2004 | 05:23 PM
blk_db2's Avatar
Try going to #3 etc then going to #10 intialize to clear all memory...
btw... I didn't hook up "VTC" or the "TDC" wire...... you don't need them unless you have I-Vtec
Old Oct 4, 2004 | 05:41 AM
vntperformance's Avatar
Can someone repost the diagram, its not showing up.
vnt
dixonsi
10
Mar 16, 2007 12:39 PM
em1_mark
May 1, 2005 08:37 AM
0 0 0
Oct 22, 2003 06:36 PM
Officer
Mar 6, 2003 07:09 PM
jteasy
Sep 17, 2001 07:13 PM
