Will Corrado g60 rotor fit on a CRX?
Old Aug 23, 2004 | 12:33 PM
HT Chaplain's Avatar
Loved
Default Will Corrado g60 rotor fit on a CRX?
Will VW carrado (sp) rotors which are the 11.1" 91 VW corrado g60 rotor in 4x100 fit on a crx or do you have to change to ex knuckles?
Old Aug 23, 2004 | 01:48 PM
crxgator's Avatar
Default Re: Will Corrado g60 rotor fit on a CRX? (HT Chaplin)
thats basically what the fastbrake kit is...
Old Aug 23, 2004 | 05:31 PM
mrchaos's Avatar
Default Re: Will Corrado g60 rotor fit on a CRX? (crxgator)
the offset is different...it wont be a direct fit
Old Sep 5, 2004 | 11:22 PM
rioninja's Avatar
I have "heard" that the corrado rotor will fit a si/dx knuckle, but will not fit an ex knuckle due to the rotor hat not being large enough.
Old Sep 6, 2004 | 12:30 AM
2point2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxgator &raquo;</TD></TR><TR><TD CLASS="quote">thats basically what the fastbrake kit is... </TD></TR></TABLE>
are you being sarcastic? if not hook a brother up with some links/info.
Old Sep 6, 2004 | 01:07 AM
rickcab1's Avatar
Default Re: Will Corrado g60 rotor fit on a CRX? (2point2)
YO(u can call up Fast Brakes yourself and he will verify it. He has told me the same thing and suggested Carrado Brake rotors as replacements for my SiR's
Old Sep 6, 2004 | 06:21 AM
V8SHME8's Avatar
Default Re: Will Corrado g60 rotor fit on a CRX? (rickcab1)
The rotors are from a 90-92 g60 and are 11" (280mm). Whether they fit, I am not sure but the kit fast brakes uses Integra calipers and brackets so you would obviously need to address the fact that the calipers are not big enough and do not reach the rotor.
Old Sep 6, 2004 | 06:28 AM
90Zcrx's Avatar
Default Re: Will Corrado g60 rotor fit on a CRX? (V8SHME8)
The kit also contains hubcentric rings. In addition, I believe there are spacers or brackets that allow you to achieve the proper offset for the calipers. I've been told it is NOT a direct-bolt on unless you have the kit.
Old Sep 6, 2004 | 09:44 AM
FakeJDMEF8's Avatar
or you could use some JAPANESE rotors...unless you want a EURO
Old Sep 7, 2004 | 05:41 PM
Loved
I was told you could use 93 prelude vtec calipers and the VW g60 rotors and it will be a direct fit. I guess i just buy them and see if they will work
Old Sep 7, 2004 | 07:51 PM
90Zcrx's Avatar
You was done lead astray. You need hubcentric rings and the proper mounting brackets. Go ahead and buy your stuff, but when you go to put it on you'll be calling fastbrakes to buy the missing parts.
Old Sep 7, 2004 | 07:54 PM
crxgator's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HT Chaplin &raquo;</TD></TR><TR><TD CLASS="quote">I was told you could use 93 prelude vtec calipers and the VW g60 rotors and it will be a direct fit. I guess i just buy them and see if they will work</TD></TR></TABLE>
its 93 prelude vtec rotors redrilled, ITR calipers and that is on 90-91 civic ex knuckles or DA knuckles...heck you can even put on NSX or Legend caliper too once you shave a bit off the bracket...
Old Sep 8, 2004 | 01:19 AM
90Zcrx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxgator &raquo;</TD></TR><TR><TD CLASS="quote">its 93 prelude vtec rotors redrilled, ITR calipers and that is on 90-91 civic ex knuckles or DA knuckles...heck you can even put on NSX or Legend caliper too once you shave a bit off the bracket...</TD></TR></TABLE>
That's the way to do it with OEM parts and it's the way I'd suggest you do it. You can get the rotors from fastbrakes.com predrilled.
Old Sep 9, 2004 | 11:54 AM
Loved
Default Re: Will Corrado g60 rotor fit on a CRX? (90Zcrx)
So you pretty much cant do anything until you swith to diff knuckles
Old Sep 9, 2004 | 12:30 PM
Jaker's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HT Chaplin &raquo;</TD></TR><TR><TD CLASS="quote">So you pretty much cant do anything until you swith to diff knuckles </TD></TR></TABLE>
Or buy the relocating brackets from Brian at FastBrakes and a set of Integra calipers.
Old Sep 9, 2004 | 12:34 PM
Loved
Default Re: Will Corrado g60 rotor fit on a CRX? (Jaker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jaker &raquo;</TD></TR><TR><TD CLASS="quote">
Or buy the relocating brackets from Brian at FastBrakes and a set of Integra calipers.</TD></TR></TABLE>
how much do those cost? and what year integra calipers?
Old Sep 9, 2004 | 12:40 PM
Jonathan_ED3's Avatar
Actually Integra and Civic EX calipers bolt onto those knuckles.
The ITR calipers are also for 11" rotors, just as the Legend and NSX calipers. For any of these you have to shave ~4mm off of the caliper mounting bracket, and then it's a direct fit w/ the redrilled rotors.
Old Sep 9, 2004 | 02:02 PM
NCchris's Avatar
Default Re: Will Corrado g60 rotor fit on a CRX? (Jonathan_ED3)
see http://hybrid2.honda-perf.org/bigbrakes.html
HTH
chris
cw1341
Aug 17, 2007 06:22 PM
User 42624
Jun 22, 2005 10:44 PM
Cowiebunga
May 26, 2005 05:09 PM
No
Apr 21, 2004 03:53 AM
xXx Justin xXx
Apr 27, 2003 10:36 AM
