Got my 404's!!
Old Aug 23, 2004 | 09:52 AM
hybrid_vtec's Avatar
Default Got my 404's!!
I got my Crower 404's(nonvtec cams) Friday and installed them over the weekend! Soon I will be off to the dyno to see what I am puttin down after the breakin period on the cams!
However I have a question, for all you 404 owner out there! Do you still have your spec cards for your 404's? Reason I am asking is b/c I dont think mine is right! Check these out and give me some feedback!
My Spec Card:
Crower 404-2
Intake: 308 degress .445 lift Exhaust: 305 degrees .434 lift
Opens: 8.0BTDC Opens: 45.0BBDC
Closes: 38.0ABDC Closes: -1.0 BTDC
Duration @ .050"
Intake: 226 degrees
Exhaust: 224 degrees
Crower website Spec Card: 62404
http://www.crower.com/misc/cam...62404
Crower Part List:
http://www.crower.com/cat/impo...shtml
Modified by hybrid_vtec at 4:12 PM 8/23/2004
Old Aug 23, 2004 | 03:08 PM
Default Re: Got my 404's!! (hybrid_vtec)
Anyone have any info for me!
Old Aug 23, 2004 | 03:12 PM
arw321's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybrid_vtec &raquo;</TD></TR><TR><TD CLASS="quote">Anyone have any info for me!</TD></TR></TABLE>
I can offer you some advice on the cam "break in" period:
Don't worry about it. Install the cams, idle at 2500 rpm or so for about 15 minutes. Drive car and beat on accordingly.
No need to "break in" cams.
Adam
Old Aug 23, 2004 | 03:46 PM
chad174's Avatar
Default Re: Got my 404's!! (arw321)
Yeah idle em for 15 and romp on them.
Old Aug 23, 2004 | 03:56 PM
Default Re: Got my 404's!! (chad174)
Crower recommended 30 min so thats what I did, however I want to put at least put another 100 miles on my car! Still in the break in period from the rebuild(sitting at 390miles)! All I need to do is stop my oil pan from leaking. It has a small drip right now(and its a new gasket)
Old Aug 23, 2004 | 04:08 PM
arw321's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybrid_vtec &raquo;</TD></TR><TR><TD CLASS="quote">Crower recommended 30 min so thats what I did, however I want to put at least put another 100 miles on my car! Still in the break in period from the rebuild(sitting at 390miles)! All I need to do is stop my oil pan from leaking. It has a small drip right now(and its a new gasket)</TD></TR></TABLE>
Slightly off topic, but how do you like the 404's so far?
Old Aug 23, 2004 | 05:09 PM
civic dx's Avatar
i love my 404's. i rather have a b18b with 404's over a stock b16 or b18c1 anyday. the cams have a lot of potental with head work. look at my untuned power curve. https://honda-tech.com/zerothread?id=968454
Old Aug 23, 2004 | 05:13 PM
jdmHboy's Avatar
What kind of compression ratio are you running?
Old Aug 23, 2004 | 05:50 PM
Darkane's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybrid_vtec &raquo;</TD></TR><TR><TD CLASS="quote">I got my Crower 404's(nonvtec cams) Friday and installed them over the weekend! Soon I will be off to the dyno to see what I am puttin down after the breakin period on the cams!
My Spec Card:
Crower 404-2
Duration @ .050"
Intake: 226 degrees
Crower Part List:
Modified by hybrid_vtec at 4:12 PM 8/23/2004</TD></TR></TABLE>
Your card is right on. Mine is in front of me right now.
Old Aug 24, 2004 | 04:52 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by arw321 &raquo;</TD></TR><TR><TD CLASS="quote">
Havent cracked in to them yet but I'll let you know this weekend!
Old Aug 24, 2004 | 04:53 AM
Default Re: Got my 404's!! (alskd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alskd &raquo;</TD></TR><TR><TD CLASS="quote">What kind of compression ratio are you running?</TD></TR></TABLE>
I am running 11.1:1 right now, but plan on bumping it up when I move back to virginia where they have better gas!
revhardallday
Nov 26, 2008 03:08 PM
$ISELLTOU4LESS$
Aug 5, 2007 10:07 AM
$ISELLTOU4LESS$
Aug 5, 2007 10:05 AM
DDD
Feb 8, 2005 08:39 AM
abacadaba
Jul 27, 2002 07:20 AM
