New parts for the Fugged up R! Radiator question, JDM front question
ok, as most of you know, i crashed my R sunday morning at 1:30 am....
from the looks of it, i obviously need a whole new front end and i need a new radiator.
i am going to replace the front end with a JDM HID front end
my question is....If i am going to have to replace the radiator anyway, should i get something better, like a fluidyne? i have a JRSC on my R by the way....
and what radiators will work with the JDM front end or is it the same? Because i know there is a diff radiator support, sorry im a newb to radiators....
thanx guys
car is at body shop, will know damage costs and such in about 2 days
thanx guys
should be the same radiator, no matter the front end.. you may even have one come with the clip you get, if you're lucky..
was your car cooling itself fine with the OEM rad? if so, I'd stick to that.. there are plenty of aftermarket options(fluidyne, C&R, etc) if you want to go that route though..
...you can use all the oem componants
