how can I make my Ls/Vtec rev higher?
get your crank/rods/pistons balanced, then get a block girdle...arp rod bolts...aftermarket valvesprings/cams combo that can take the amount of rpm that you want...basically, you have to build a motor that will be able to take the beating of higher revs and compression.
buy a chipped ecu with no rev limiter and blow your engine sky high or build it with good parts head work also work on the bottom. Always remember cheap parts aren't good and good part aren't cheap.
Rod bolts for stock rods (or a good set of rods), gsr main girdle ( or z10 ), block guard ( or get it sleeved ), and thats just a start with the block.
Then you probably already know what to do with the head.
