poly or rubber ta bushing
Old Aug 22, 2004 | 08:23 PM
eda6's Avatar
Default poly or rubber ta bushing
what do you prefer? poly or rubber? and why
just finished up es master kit install. need to finish rear before i go to the alignment shop.
thanx
Old Aug 22, 2004 | 08:38 PM
Superhatch's Avatar
Default Re: poly or rubber ta bushing (eda6 hb)
Ive got the mugen hard rubber bushings...and I love them. If I could afford them I would use them only.
Old Aug 23, 2004 | 12:46 PM
travis's Avatar
Default Re: poly or rubber ta bushing (Superhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Superhatch &raquo;</TD></TR><TR><TD CLASS="quote">Ive got the mugen hard rubber bushings...and I love them. If I could afford them I would use them only.</TD></TR></TABLE>
ditto.
Old Aug 23, 2004 | 08:36 PM
eda6's Avatar
Default Re: poly or rubber ta bushing (travis)
How is trailing arm movement affected by each bushing type?
what's the best for high speed driving?
Old Aug 23, 2004 | 11:35 PM
MestizoRacer310's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eda6 hb &raquo;</TD></TR><TR><TD CLASS="quote">How is trailing arm movement affected by each bushing type?
what's the best for high speed driving?</TD></TR></TABLE>
Honestly, I'd be more worried about how it takes the stress of hard turning than going fast straight...but yeah, I'd like to know too about poly bushings...are they really that much of an upgrade?
Old Aug 24, 2004 | 08:11 PM
eda6's Avatar
Default Re: poly or rubber ta bushing (MestizoRacer310)
I know this isn't an interesting topic, but i need answers
Old Aug 24, 2004 | 08:34 PM
Change's Avatar
well it doesnt rot away as fast as rubber...
Old Aug 25, 2004 | 12:12 AM
REX VT's Avatar
Are you kidding? It's the best ******* upgrade available!
Old Aug 25, 2004 | 02:44 AM
AgentJam's Avatar
Default Re: (REX VT)
yeah they are the bomb...made a huge difference in responsivness of my crx. Just think those poly bushings dont really flex at all they are solid. If every rubber bushing on your suspension gives 3-4mm you've got some sway on your hands.
Just remember that you will feel every pebble in the road...and hear it bang your car as well.
go for it.
Vince
Old Aug 25, 2004 | 03:04 PM
Default Re: (AgentJam)
Am I also being told correctly that changing to aftermarket bushings they won't be "as solid" as the oem rubber....meaning they aren't "vulcanized" into the mount??
Old Aug 25, 2004 | 03:11 PM
Tyson's Avatar
you know, its not like poly doesnt deflect any at all. its actually pretty soft compared to metal. its just designed so that it doesnt allow the middle bone to move freely at all, except rotate. whereas the stock rubber does, which is something to consider when you think that thats how the honda suspension engineers DESIGNED it to be....
heres a comparison of a 700lb load on a suspension bushing with poly.
no load.
http://www.imagestation.com/pi...2.jpg
700lbs = 1/8" deflection
http://www.imagestation.com/pi...1.jpg
Modified by Tyson at 4:25 PM 8/25/2004
Old Aug 25, 2004 | 06:39 PM
AgentJam's Avatar
Default Re: (Tyson)
I agree poly isn't as hard as metal but is that really the arguement here?! Caman guys just take a look at the stock bushings...i remember when removing mine how easy it was to stick a screwdriver in the sleeve and push it around.
It's a difference that can be felt without even thinking about it
Vince
Old Aug 25, 2004 | 07:20 PM
travis's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AgentJam &raquo;</TD></TR><TR><TD CLASS="quote">
What an ironic statement.
I belive Tyson's point was that most of the poly bushings on the market differ from OEM in both material and design, and the differences in design are a function of cost rather than performance. The articulation of the rear trailing arm doesn't lend itself well to fixation. If it did, we could just replace it with a steel bearing.
07siftw
Honda Civic (2006 - 2015)
21
Feb 14, 2008 07:17 PM
NathanMorris
Suspension & Brakes
Feb 13, 2008 08:22 AM
JCracer723
15
Oct 17, 2006 02:23 PM
SLO Sol
Oct 25, 2005 09:14 AM
JDM TypeR 307
Mar 5, 2004 03:22 AM
