B20vtec knock with low octane need Help figuring it out...
Old Aug 22, 2004 | 07:41 PM
bpowa's Avatar
Default B20vtec knock with low octane need Help figuring it out...
the motor is b20vtec, Stock. it is the low comp one
anyway I knoticed with 87 octane gas it makes a knocking sound at low rpm, like when I cruise 40 miles in hour in 5th gear a give it some gas...
So i used 91 octace and it does not do it anymore.. does anyone know what cause this? my comp is about 9:1.. i rather use 87 to save some spare change.. anyone knows where the noise can come fron.. valves, rods, bearings etc??
TIA
Old Aug 22, 2004 | 10:13 PM
lemongreenhatch's Avatar
Default Re: B20vtec knock with low octane need Help figuring it out... (bpowa)
from dealer it calls for 93 octane
Old Aug 22, 2004 | 10:16 PM
Veris's Avatar
Your ignition is probably advanced to much. B20s run best with ignition retarted a degree or two when running on a vtec ecu.
Old Aug 23, 2004 | 10:42 AM
bpowa's Avatar
Default Re: B20vtec knock with low octane need Help figuring it out... (Veris)
i want to know is it the gas... like i said 91 octane it runs fine but, 87 it klunks in low rpm..
we only have 91 octane here, its the highest, they took 93 couple years ago..
Old Aug 23, 2004 | 10:50 AM
porsche997dc2's Avatar
I was running 87 for my b20vtec couple years ago. It knocked. I try 89 same ****. Try 91, the motor ran like a champ. You might try to retard the timing a little.
Old Aug 23, 2004 | 10:58 AM
Combustion Contraption's Avatar
Its called detonation. Your fuel is igniting itself before the spark. Like stated in previous posts, retard your timing.
Old Aug 23, 2004 | 11:48 AM
JDMFreak's Avatar
i know gas is sky rocket at the moment...im not trying to be a hard ***...but you got a better motor and that motor need it gas....i would try to maintain 91+ octane
Old Aug 23, 2004 | 02:04 PM
krazie1's Avatar
BANNED
I thought everyone knew as soon as u put in type of swap u should always use higher octane
since detonation occurs
but I guess I assumed
all swaps should be pump 91 or better if not kiss the life of the swap good bye
and u got a crvtec!!!!!
sorry but it is like buying a Benz and eating at Macdonalds....
just doesn't make sense
Old Aug 23, 2004 | 02:07 PM
Propulsion's Avatar
Default Re: B20vtec knock with low octane need Help figuring it out... (krazie1)
lets hope your sleeves didn't crack, it doesn't take much knock for them to give. Do a compression check asap.
Old Aug 23, 2004 | 05:51 PM
bpowa's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by krazie1 &raquo;</TD></TR><TR><TD CLASS="quote">I thought everyone knew as soon as u put in type of swap u should always use higher octane
just doesn't make sense </TD></TR></TABLE> mines is low compression
i retareded the timming a bit.. not sure where at though, because i have no timming light.. mines broke.. so i pumped a few dollars worth of 87 gas to check.. the low rpm knock is gone... funny thig is vtec pops harder.
the reason why i pour 87 gas is because, i am a broke *** student; 87 octane i can buy a pack of smokes with a fill up. and this vtec head i added on cost more than i expected...
detonation; can some one explain how this happen, and what will it mess up. i am thinking valves; some one clue me in.
Old Aug 24, 2004 | 11:50 AM
vtecdamian's Avatar
******* cheapass ITS CALLED PINGING!!!!!!!!!!!!!! THAT **** IS GONA BREAK...WHEN YOU HEAR DETONATION.....THAT MEANS ITS REAAAALLLLLY BAD...PUT SOME 93!!!!!
MY FRIEND PUT 89 IN MY B20VTEC ONCE I HAD TO DRAIN IT AND ADD 93
Old Aug 24, 2004 | 12:24 PM
*sigh*
an eninge mixes air and fuel and ignites it with a spark. When the piston is traveling upward on its compression stroke, it reaches the top, and the spark plug "fires". The following explosion throws the piston down the cylinder. This force is what moves your vehicle foward. Detonation is when the fuel starts igniting by itself, like when the piston is only halfway up on its compression stroke. You can imagine how good this is for pistons and bearings, oh and cylinder walls. Come to think of it, its not good for anything. Quit smoking, fill it up with premium.
Old Aug 24, 2004 | 12:45 PM
Paulnsx's Avatar
read this http://auto.howstuffworks.com/engine1.htm alot of the info there is real basic... but there is some good info buried in there. it might not actually cover knocking in there, but reading that and reading lsvtec's explaination of it will help you make sense of it.
also i like lsvtec's advice "Quit smoking, fill it up with premium."
Old Aug 24, 2004 | 03:54 PM
NSTY Z33's Avatar
You should def, quit the smokes, and spend the money on higher octane.
Either get stuck, walk to school while you smoke a pack, or just save $$ and be healthy. It's obvious that 87 is definately needed if you hear knock on 87 and not 93.
Old Aug 24, 2004 | 09:10 PM
bpowa's Avatar
Default Re: B20vtec knock with low octane need Help figuring it out... (vtecdamian)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecdamian &raquo;</TD></TR><TR><TD CLASS="quote">******* cheapass ITS CALLED PINGING!!!!!!!!!!!!!! THAT **** IS GONA BREAK...WHEN YOU HEAR DETONATION.....THAT MEANS ITS REAAAALLLLLY BAD...PUT SOME 93!!!!!
MY FRIEND PUT 89 IN MY B20VTEC ONCE I HAD TO DRAIN IT AND ADD 93</TD></TR></TABLE>
idiot, i did not say it was a ping... i can hear the difference between a knock and ping.. The only real reson why i pour 87 is my compression is low. if i had higher compression i would not pour 87. read first smartass..
i poured 87 because i read my motor did not need high octane.. so why waste the money if not need to... like i said earlier, the knock sound went away after i lowered the timming.. i just wanted to know why it happened in the first place.
now i just want to find out more about what causes it.. thanks lsvtec92 for the input...
as for smoking i tried mant times anyone who smoked for years will say they rather quit.. but i dont want to get into that topic..
Old Aug 24, 2004 | 09:35 PM
no problem. But if you retarded your timing and the knocking noise went away, its probably ping buddy.
Old Aug 25, 2004 | 04:29 AM
daidilus's Avatar
err umm man...you have a CRVTEC...you need high octane......it is a vtec motor now..if you have knocking......up your octane.....or dont drive it....why mess up a motor because you wanna mess up your lungs.....retard the timing...up the octane to 90...at least.....and quit trying to find other things wrong than the obvious
Old Nov 19, 2004 | 11:16 AM
Insane Beast's Avatar
Default Re: (daidilus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by daidilus &raquo;</TD></TR><TR><TD CLASS="quote">err umm man...you have a CRVTEC...you need high octane......it is a vtec motor now..if you have knocking......up your octane.....or dont drive it....why mess up a motor because you wanna mess up your lungs.....retard the timing...up the octane to 90...at least.....and quit trying to find other things wrong than the obvious</TD></TR></TABLE>
that_sick_eg
Jun 8, 2009 10:42 PM
JDM_Spec
Aug 26, 2005 01:34 AM
purpl7duece
Nov 16, 2002 01:15 PM
capcon83
Oct 31, 2002 02:30 PM
ragejed
Sep 21, 2002 09:36 PM
