my new motor come see it-thoughts/opinions welcomed.
Old Aug 22, 2004 | 06:40 PM
hayabusa160's Avatar
Default my new motor come see it-thoughts/opinions welcomed.
well heres a video of my new motor i just put on my eg.
http://www.pegasus.rutgers.edu...9.MOV
i'll give a brief spec on it
gsr motor
ls crank and rods
ported head, and bored out throttle body, and ported gsr manifold.
skunk2 valvetrain and skunk2 stage 2 cams
jdm type r pisons
hacked on stock gsr intake arm to my stock air box off my d15
and a stock b16 header
hondata s200
oh yea type r tranny
driving around open header at the moment.
in that video vtec was not on because of my stupid vss not working. vtec only kicks on once in a while when the vss decides to go nuts.
Old Aug 22, 2004 | 07:42 PM
slammed_93_hatch's Avatar
Default Re: my new motor come see it-thoughts/opinions welcomed. (hayabusa160)
sounds nice, just curious why the use of LS crank and rods?
i never really pay attention to bottom end build on hondas
Old Aug 22, 2004 | 07:47 PM
5STAR3's Avatar
Default Re: my new motor come see it-thoughts/opinions welcomed. (slammed_93_hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slammed_93_hatch &raquo;</TD></TR><TR><TD CLASS="quote">sounds nice, just curious why the use of LS crank and rods?
i never really pay attention to bottom end build on hondas</TD></TR></TABLE>
longer stroke.
Old Aug 22, 2004 | 07:55 PM
Default Re: my new motor come see it-thoughts/opinions welcomed. (envision2teg)
ya the ls vtec the right way lol
Old Aug 22, 2004 | 08:17 PM
5STAR3's Avatar
your speedo doesnt work?
Old Aug 22, 2004 | 08:19 PM
NEXTAMERICANIDOL's Avatar
I'm not sure put I thought you can't use a b16 header on a GSR because of the deck hight.
Old Aug 22, 2004 | 08:28 PM
Default Re: my new motor come see it-thoughts/opinions welcomed. (NEXTAMERICANIDOL)
yea my speedo dont work vss is broke
the b16 header fits fine was alittle bit hard to get on but it fits not a problem
Old Aug 22, 2004 | 08:30 PM
743power's Avatar
what basemap are you running with that hondata? Sounds like there is a lot of hesitation between shifts. Can't you disable the VSS with hondata, also?
you need to get rid of that "header" asap.
Old Aug 22, 2004 | 08:43 PM
Default Re: my new motor come see it-thoughts/opinions welcomed. (743power)
i was granny shifting maybe thats why. but now you mention it there is a slight hestation between shifts as for the basemap no clue i gaive my set up to wirespeed and he hooked me up with a base map the car deff needs tuning right now idle is rough. i check the plugs its not too rich. its no lean either so its ok for now.
i just finished the swap 3 days ago so im still working some bugs out
Old Aug 22, 2004 | 08:48 PM
dc2legend's Avatar
What does the actual cc's come to on that setup. Just the same as an LS?
Old Aug 22, 2004 | 08:49 PM
743power's Avatar
Default Re: my new motor come see it-thoughts/opinions welcomed. (dc2legend)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dc2legend &raquo;</TD></TR><TR><TD CLASS="quote">What does the actual cc's come to on that setup. Just the same as an LS?</TD></TR></TABLE>
probably, deck height is the same on both blocks. For some reason, I always thought something about that combo didnt work, but I guess it does.
Old Aug 22, 2004 | 08:51 PM
yep 30 somethin cc more over the gsr i dont kno the exact number im gettin old cant rember anything any more. gsr had a 87.5 stroke ls has a 89mm stroke
i was suppost to get a pro fab header from spark racing but sadly it never came 2 weeks aready. i was going to do a dyno with it vs the stock gsr header. sadly it never came so i had to borrow my friends b16 header for now.
i might request my money back and buy a comptech header i saw a few up for sale.
Old Aug 23, 2004 | 07:24 AM
w00t fixed the vss problem now
i had to cut my old clip off my old harness and solder it on now it works like a charm
Old Aug 23, 2004 | 10:14 AM
dc2legend's Avatar
Nice, keep us posted on this...
Old Aug 23, 2004 | 03:22 PM
plan to take it to the dyno soon as i get the header and intake
Old Sep 12, 2004 | 07:33 PM
bump back from the dead i have a apexi ws exhaust.
should i change it out? i kno its baffled and has that taper at the flang where it meets the cat because it was designed for the smaller d16 motor.
i think it tapers down to 2inch then back to 2.25
my header is 2.5inch so im pretty sure that taper is killing the flow pretty bad.
i kinda like this exhaust because its so quiet. maybe cut that taper off?
i was thinking about the kteller 2.5 all the way back and mate it to a tanabe hyper medallion 3 inch muffler looks almost like my ws but straight through. any opinions on this?
xbox617
Apr 25, 2008 09:20 PM
STRAKTUS
18
Oct 22, 2007 06:33 AM
rough_draft
Mar 16, 2005 10:15 AM
crxsirvtec
Jan 26, 2004 06:20 AM
jaydmcrx
13
Jan 4, 2004 04:24 PM
