Question about how an electronic boost controller that uses solenoids works using a Duty cycle.
Old Aug 22, 2004 | 06:09 PM
Sinner's Avatar
Default Question about how an electronic boost controller that uses solenoids works using a Duty cycle.
I'm trying to figure out the duty cycle of EBC that use solenoids.
Is this a cycle that turns the solenoid off/on many times a second to keep boost steady? Or does it turn on and off once a second to keep boost steady? Is this a ratio of on/off per second? I'm really guessing here...
Nick
Old Aug 22, 2004 | 06:16 PM
Sinner's Avatar
is the signal sent to the solenoid a digital or a pwm signal?
Old Aug 22, 2004 | 06:46 PM
Chris F's Avatar
Default Re: Question about how an electronic boost controller that uses solenoids works using a Duty cycle.
It would have to be pwm, in order to hold boost even close to steady. Closing the WG for a second would totally overboost on most people's setups.
Old Aug 22, 2004 | 06:52 PM
Sinner's Avatar
I agree, and the solenoid what have to be a fast solenoid otherwise it wouldnt open/ close fast enough.
Old Aug 22, 2004 | 07:11 PM
Jared's Avatar
Default Re: (Sinner)
its a pwm signal on most, much like an evap purge solenoid or an idle motor.
mozzandherb
Jul 27, 2010 06:02 PM
1baddturbosi
Dec 5, 2006 11:35 AM
Big Wood
Jan 7, 2006 04:25 PM
mrx
Jan 31, 2004 05:33 AM
