Is a 100k miles itr reliable still or just going to cause problems here and there
Old Aug 22, 2004 | 04:30 PM
trainingday's Avatar
Default Is a 100k miles itr reliable still or just going to cause problems here and there
im thinking of buying a itr but i only have 10k max
and i had found 2 potential in my range... both over 1ook miles STOCK CONDITION though... looks ook
Im def getting a teg gsr or itr no doubt.
But i do alot of coast to coast long driving trips
what problems can come with high mileage cars like ITR
Old Aug 22, 2004 | 04:36 PM
REDTOPAlchemy's Avatar
Default Re: Is a 100k miles itr reliable still or just going to cause problems here and there (trainingday)
I would be more worried about thieves than high milage. Just make sure the car was taken care of (ie. service records). A high mileage engine is only as good as the maitenance it recieves. Other than that it will run just as strong as its lower milage counterparts.
Old Aug 22, 2004 | 04:37 PM
743power's Avatar
It's a honda, as long as it was reasonably maintained, it will be fine. Ask the owners when they last changed t-belt and pumps, ask them if you can do a compression test before you buy. Check for trans grinds and other obvious things.
If the car is in good shape and stock or relatively stock, the mileage shouldn't stop you from buying it.
Old Aug 22, 2004 | 05:23 PM
Chris F's Avatar
Default Re: Is a 100k miles itr reliable still or just going to cause problems here and there (743power)
I drove a Prelude to 200,000 miles. Tranny went bad after that and wasn't worth replacing... I miss that car
Maintenance gets more expensive after 100K but it ought to be reliable.
-Chris
Old Aug 22, 2004 | 05:29 PM
sk8's Avatar
sk8
Default Re: Is a 100k miles itr reliable still or just going to cause problems here and there (ccfries)
I just past 100k. It still runs
Old Aug 22, 2004 | 06:14 PM
Champ R's Avatar
Definitely get a detailed examination from a trusted mechanic somewhere. Properly maintained like others said, the ITR motor will last just as long as any other honda motor if treated properly. A seller with extensive maintenance records usually yield better cars.
Old Aug 22, 2004 | 08:10 PM
Bbasso's Avatar
51k <U>very hard</U> miles on mine and it still goes...
**** load of smoke and tranny grinds
I plan on making it to 100 with no motor rebuild, but a tranny rebuild one or twice before then .
Honda Motors that are well taken care of will last untill you don't take care of them.
Old Aug 22, 2004 | 08:16 PM
98itR484's Avatar
Default Re: (Bbasso)
56k VERY HARD MILES here, 50k or so of them being with bolt ons and different cams/valvetrain...still running stong, and NO SMOKE..tranny is gone tho..second time
Lynx
Apr 27, 2009 07:38 AM
hooptie157
Nov 1, 2007 06:56 AM
nbaonabc
Aug 2, 2004 03:05 PM
itr561
Jan 1, 2003 07:08 PM
OneThirtyEight
Sep 4, 2001 12:25 PM
