I don't think this was posted in the prelude section at all but check this out...
Old Aug 22, 2004 | 04:30 PM
rjr162's Avatar
Default I don't think this was posted in the prelude section at all but check this out...
I don't know what RPM it would be limited too if it is stroked that big, if it's even possible on the H block... or what bore, etc. If this is for real that's nuts!
http://cgi.ebay.com/ebaymotors...33613
3.0 liter H series engine???
Old Aug 22, 2004 | 04:46 PM
fireslinge's Avatar
Default Re: I don't think this was posted in the prelude section at all but check this out... (rjr162)
my entire car cost less than that engine....
Old Aug 22, 2004 | 04:54 PM
Nikoli's Avatar
Default Re: I don't think this was posted in the prelude section at all but check this out... (fireslinge)
they had thread on this in GDD
Old Aug 22, 2004 | 05:22 PM
UA6 BALLER STATUS's Avatar
Default Re: I don't think this was posted in the prelude section at all but check this out... (Deckedlude)
Ive seen it somewhere in H-T not to long ago.
Old Aug 22, 2004 | 05:25 PM
rjr162's Avatar
ya, my brother found it in the tech section I think, but I didn't know how many of you guys checked that area out
Old Aug 22, 2004 | 05:26 PM
Matgallis's Avatar
Default Re: I don't think this was posted in the prelude section at all but check this out... (Type SH)
seems kind of shady since it's not even built yet...
Old Aug 22, 2004 | 05:43 PM
Kal's Avatar
Kal
Default Re: I don't think this was posted in the prelude section at all but check this out... (Matgallis)
i rather get a K engine.
Old Aug 22, 2004 | 05:52 PM
eLUDEnu
Guest
Posts: n/a
Default Re: I don't think this was posted in the prelude section at all but check this out... (Kal)
id give my left nut!!!!!!!!1
Old Aug 22, 2004 | 05:56 PM
Behan's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rjr162 &raquo;</TD></TR><TR><TD CLASS="quote">ya, my brother found it in the tech section I think, but I didn't know how many of you guys checked that area out</TD></TR></TABLE>
link?
Old Aug 22, 2004 | 06:05 PM
Rick Solis's Avatar
Default Re: I don't think this was posted in the prelude section at all but check this out... (eLUDEnu)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eLUDEnu &raquo;</TD></TR><TR><TD CLASS="quote">id give my left nut!!!!!!!!1</TD></TR></TABLE>
I wouldnt...
to achieve a 3.0 with a 92mm bore which in itself is just retarded (changing the bore spacing???), would require a 113+mm stroke...
Can you say... "very expensive boom"
Old Aug 23, 2004 | 04:59 PM
fireslinge's Avatar
k series would be much better...
Old Aug 23, 2004 | 06:22 PM
fastludeh22's Avatar
Default Re: I don't think this was posted in the prelude section at all but check this out... (Rick Solis)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rick Solis &raquo;</TD></TR><TR><TD CLASS="quote">
I wouldnt...
???</TD></TR></TABLE>
i agree EXCEPT
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pocketrockets_racing &raquo;</TD></TR><TR><TD CLASS="quote">
the deck has been extended to accomodate a good rod/stroke ratio</TD></TR></TABLE>
im not saying this guy is true, but with money it could be done.
Old Aug 23, 2004 | 06:28 PM
Rick Solis's Avatar
Default Re: I don't think this was posted in the prelude section at all but check this out... (fastludeh22)
Theres nothing you can do to remedy the effects of the piston speeds created from the 113+mm crank... That thing wouldnt be able to turn more than 4k with out running into problems... Even with say, a 2 inch deck plate which is insane and retarted... Thats not going to solve bearing issues your almost guaranteed to run into...
The oil pump gear is almost guaranteed to shatter as well...
Old Aug 23, 2004 | 06:46 PM
Matgallis's Avatar
why limited to 4k? Can u please go into depth...
Old Aug 23, 2004 | 07:01 PM
Rick Solis's Avatar
Not necessarely 4K (exagguration) but it would have to keep pretty low... Piston speeds would be outrageous even at 5000-6000
Old Aug 23, 2004 | 07:12 PM
Rick Solis's Avatar
Heres an example...
H22 @ 8000 = 4,760
H23 @ 7500 = 4,675
H30 @ 6000 = 4,448
Old Aug 23, 2004 | 07:13 PM
Kal's Avatar
Kal
i say someone dish out 14000 to be the guinea pig
Old Aug 24, 2004 | 12:00 AM
safe driver's Avatar
completely and utterly unnecessary. keep it simple, stupid.
Old Aug 24, 2004 | 07:59 AM
prelittlelude's Avatar
yeah i saw this too, what i wondered is how the F would he get a 92mm bore, and still retain engine integrity, most people say 90mm is insane for the H,
i mean jesus 113 mm storke though, that like a desil engine.
edit hold on guys im just going to go to the bank and be right back
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">
H30 turbo 3.0 L, with brand new cylinder head, brand new transmission with quaife LSD, nothing but the best full ball bearing turbo system, multi throttles,, programmed EMS, dyno tuned, turnkey $36,945.00...no core charge. </TD></TR></TABLE>
Old Aug 24, 2004 | 09:04 AM
PrecisionH23a's Avatar
Wow, it didn't sell. I wonder why.
1993-eg1
Apr 16, 2008 07:26 AM
PearlH22
Jul 4, 2006 01:39 PM
XiOus271
Apr 29, 2006 12:35 PM
whatVTEC
May 5, 2005 12:46 AM
b18cinmycrx
10
Sep 14, 2004 12:50 PM
