front camber problem on 90 hatch with 18's and 2" drop
Old Aug 22, 2004 | 03:19 PM
esp4life's Avatar
Default front camber problem on 90 hatch with 18's and 2" drop
radials are exposed on front tires. like alot. the car has 18's and a 2" drop. i talked to the local alignment shop and they said a camber adjuster would go through the fender. what to do?
Old Aug 22, 2004 | 03:30 PM
jhota's Avatar
Default Re: front camber problem on 90 hatch with 18's and 2" drop (esp4life)
wth does "camber adjuster would go through the front fender" mean?
if they mean it'll make the tyre hit the fender, i'd suggest rolling the fender lip if you haven't already.
also, you don't need to be in-spec for camber to minimize inner edge wear; i'm curious what your car is actually at...
Old Aug 22, 2004 | 03:39 PM
EJ2-Fluffy's Avatar
Default Re: front camber problem on 90 hatch with 18's and 2" drop (jhota)
Meaning..the camber kit (im guessing yours is running on the ED chassis) bolt that goes in for the Adjustable Ball Joint will hit the fenders. How to overcome such a problem? Ground the Nut connected to the Balljoint Bolt just a lil bit.
-Jon
killercrx91
Nov 3, 2008 01:00 AM
EF9SIRJeff
23
Apr 5, 2008 10:45 AM
mikeycivic
Suspension & Brakes
Mar 31, 2008 04:00 PM
Nsane1
Apr 26, 2004 09:26 PM
typeSwarrior
Jun 8, 2002 06:18 AM
