Front rotor removal, help with the screws
Old Aug 22, 2004 | 01:07 PM
SuperSteve737's Avatar
Default Front rotor removal, help with the screws
So yesterday my front brakes on my '91 CRX HF started to squeek so I went to AutoZone this morning and went to change out the rotors and pads. I got the passenger side all done, no problem. Then I switched over to the driver's side and now I have a problem.
I can't get the screws that hold the rotor into the hub off. I used a big screwdriver and was hitting the end with a hammer while turning, then tried some PB Blaster and the same method. I am scared to strip out the screw and I think that is going to happen next. Any ideas or help? TIA.
-Steve
Old Aug 22, 2004 | 01:48 PM
ls_vtec_crx's Avatar
use a flat head screwdriver and a hammer....hit it side ways....worked for me
Old Aug 22, 2004 | 01:57 PM
MonkeyMagic's Avatar
Default Re: (ls_vtec_crx)
the proper way is to use an impact screwdriver. its just a screwdriver you smack at the end instead of turning with your hand. rent it from autozone for cheap, other wise goodluck
Old Aug 22, 2004 | 01:59 PM
Blueallie's Avatar
Default Re: Front rotor removal, help with the screws (SuperSteve737)
You can buy them for cheaper than you can rent them. Autozone charges 40 dollars I think. I paid 29.99 at sears for mine.
Old Aug 22, 2004 | 02:03 PM
jc836's Avatar
Buying the Impact Driver kit from Sears is actually a very good investment overall. Just be sure to also buy a suitable hammer (2+ pound sledge works great). You will find a lot of uses for it (and so will your neighbors <G&gt. The screws are not expensive from Honda (40 cents each) and I replace them each time (just my preference).
Old Aug 22, 2004 | 02:20 PM
GreenMachineRex's Avatar
Default Re: Front rotor removal, help with the screws (jc836)
u don't even need those gay little screws. if worst comes to worst drill the heads of them off. i had to do that once.
only if i had a nickel for everytime someone posted about this...
Old Aug 22, 2004 | 04:22 PM
SiRex91's Avatar
Default Re: Front rotor removal, help with the screws (GreenMachineRex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GreenMachineRex &raquo;</TD></TR><TR><TD CLASS="quote">u don't even need those gay little screws. if worst comes to worst drill the heads of them off. i had to do that once. </TD></TR></TABLE>\
I got mine off the other day with the help of my Dewalt 18v
**** those useless rotor screws
Old Aug 22, 2004 | 04:28 PM
FourthGenHatch's Avatar
Honda is the only company I ever saw with rotor screws. No Toyotas I have ever worked on had them.
Old Aug 22, 2004 | 06:19 PM
Yeah, my old hatch didn't have them in. But anyways, was at my fiance's uncles for a loss in the family and her uncle had an impact screwdriver and took it right out. Thanks for the advice, guys and gals.
zirac50
May 3, 2007 05:15 PM
Discontained
10
Jan 21, 2007 04:46 PM
shawn_crx
Mar 4, 2005 01:06 PM
Drag-On23
Oct 28, 2003 08:29 AM
highmilehatch
Apr 10, 2003 02:00 PM
