Is the K20A DC5 Integra Type R worth $5,500
Old Aug 22, 2004 | 01:07 PM
Butler2's Avatar
Default Is the K20A DC5 Integra Type R worth $5,500
I need some more power!
Old Aug 22, 2004 | 01:43 PM
Kal's Avatar
Kal
Default Re: Is the K20A DC5 Integra Type R worth $5,500 (Butler2)
I assume you're talking about the engine...
and yes it is worth that much.
Old Aug 22, 2004 | 01:58 PM
Butler2's Avatar
Default Re: Is the K20A DC5 Integra Type R worth $5,500 (Kal)
Yes, I am.. Is it any different than the one thats in the rsx type-s
Old Aug 22, 2004 | 03:13 PM
jdkindle's Avatar
I say no......unless you want something to just buy and be done with
differences; cams, manifold and pistons
so if you plan on replacing any of those, just get an S motor IMO
Old Aug 22, 2004 | 03:49 PM
DC5ITR329's Avatar
Default Re: (jdkindle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdkindle &raquo;</TD></TR><TR><TD CLASS="quote">I say no......unless you want something to just buy and be done with
so if you plan on replacing any of those, just get an S motor IMO</TD></TR></TABLE>
I agree. however the Type R tranny is alot better because it's shorter gears for NA and you get a LSD.
Old Aug 22, 2004 | 05:32 PM
Kal's Avatar
Kal
Default Re: (aznbo1626)
it also comes with a manifold designed to make power in the higher revs.
Old Aug 23, 2004 | 08:02 AM
krystar's Avatar
difference between K20A and the K20A2 (the rsx type s engine)
K20A has 11.5:1 compression pistons, more aggresive cams, bigger intake manifold.
for 5500, i'm guessing you're getting an entire front clip. that also means you'll get a 6spd tranny with tighter gearing, a LSD, the typeR ecu.
Old Aug 23, 2004 | 12:00 PM
RsxVengeance's Avatar
no worthy unless you coming from a base rsx.
Old Aug 23, 2004 | 01:09 PM
wrgsurfer's Avatar
I have a wrecked, mint condition 2002 acura rsx type s with a perfect motor and transmission I'm willing to part out. Motor and trans. complete for $3,000. If interested, email me wgalinat@aol.com for pictures and/hear it run.
Old Aug 23, 2004 | 01:10 PM
pints99's Avatar
Default Re: Is the K20A DC5 Integra Type R worth $5,500 (wrgsurfer)
You may side with the k20a2 because it will cost a decent amount less, but your chocie is your choice. All the k20a parts are interchangeable with the k20a2 so you can always just swap in the type R parts or superior aftermarket parts later.
enoker001
23
Feb 16, 2008 08:33 AM
jdm_vizionz
Aug 14, 2007 09:34 AM
B18cHatch06
Dec 9, 2004 06:37 PM
Wattup Though 00
May 2, 2004 07:34 PM
Another LeveL DJS
12
Feb 5, 2004 06:52 AM
