96 spec itr cluster compatable with ls ??
when i installed it in my 95, only the rpm and speedo worked. does anybody have the instructions for it to fit ?? the wiring scematics ?? i searched and only came up with gsr installations. the fuel, coolant temp, and everything else didnt worked.
You sure it was a 96 spec? Does it have the catalytic overheating icon in the top left? Anyways, swap the green film on the back of your LS cluster onto the ITR one and you should be good.
