over bore on a B20?
Old Aug 22, 2004 | 10:07 AM
AllMoToRB18c's Avatar
Default over bore on a B20?
has anyone ever did 84.5mm on B20 block..the reason im askin is because i might get a b20 longblock that has bad rings and if the cylinder walls are messed up i wanna know if i can do 84.5 on it...any info will be great
Thanks in advance
Old Aug 22, 2004 | 11:01 AM
asubennett's Avatar
Default Re: over bore on a B20? (AllMoToRB18c)
You wil be more than fine. You can go 85mm if you want. @85mm it can get a little nerve racking b/c the tops of the cylinder walls are prone to cracking with very high compresion.
Old Aug 22, 2004 | 11:10 AM
indomotor's Avatar
Default Re: over bore on a B20? (asubennett)
I had 2 motors w/84.5 both ran great.One is still running strong
Old Aug 22, 2004 | 11:11 AM
well im just lookin to do 84.5 with 12.5:1 compression....if the walls arent messed up then i wont over bore at all...but thanks for the info..do u think a block guard will keep it from crackin at 85mm?
Old Aug 22, 2004 | 11:56 AM
Jay D EM DC2's Avatar
a buddy of mine did 84.5 and with block posting the motor made 233whp and 151ft-lbs on 93 octane
Old Aug 22, 2004 | 02:36 PM
vtecdamian's Avatar
Default Re: (Jay D EM DC2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jay D EM DC2 &raquo;</TD></TR><TR><TD CLASS="quote">a buddy of mine did 84.5 and with block posting the motor made 233whp and 151ft-lbs on 93 octane</TD></TR></TABLE>
that was me yes i am 84.5 and cp 12.5:1 pistons.......make sure u dont detonate (ping) thats what causes the cylinder to crack.......
byw it was 233.8 whp bitch get it right and 155 tq!
Old Aug 22, 2004 | 04:57 PM
slimbo's Avatar
Default Re: (vtecdamian)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecdamian &raquo;</TD></TR><TR><TD CLASS="quote">
byw it was 233.8 whp bitch get it right and 155 tq!</TD></TR></TABLE>
what are you revving it to?
i've been told not to turn it past 8500 in the interest of not cracking sleeves... apparently the harmonics can lead to cracking.
i hate being poor, if i had the money i would have re-sleeved it.
Old Aug 22, 2004 | 06:48 PM
it's fine to rev to 8500, but anything past that a block gaurd or sleeve posting would be a must, but damian has no fear and rev's it like a motorcycle.
Old Aug 22, 2004 | 10:22 PM
C.A.M.'s Avatar
vtecdamian,
Just curious, did you build you own motor?.. and also, who tuned your motor for you, or did you tune the motor youself?
Hows the revving?
any 1/4 E.T. times yet?
reason, im asking is because my b20 block was being bored and found it had a hair crack, I had it resleeved. with a block guard, motor is around the corner just about done.
Old Aug 22, 2004 | 11:33 PM
yea he built his own motor, and he's building mine, but he's running hondata s200, and Secret Services of Tampa FL that's closed down tuned his car. it revs like a motorcycle and he's gotten a 12.8@104 i think with slipping clutch, and slicks that aren't sticking to the rims. also in 90+ degree high humidity weather in south florida
Old Aug 23, 2004 | 07:08 AM
well im lookin to rev to like 9300 maybe....u think i would need a block guard then?
Old Aug 23, 2004 | 09:13 AM
yes, and invest in a block girdle also.
Old Aug 24, 2004 | 06:31 AM
anyone else got any input on this topic...need as much info as possible
Old Aug 24, 2004 | 10:20 AM
vtecdamian's Avatar
Default Re: (AllMoToRB18c)
ME AND MY MECHANIC BUILT MY MOTOR....OT REVS 9000 AT THE TRACK AND STREET AND HAS SEEN A FEW 10,000 RPM MISSHIFTS...................TUNED BY JOHN AKA VAPORTRAIL AT SECRET SERVICES!
Old Aug 25, 2004 | 06:12 AM
so to run a b20 at 84.5mm and at 12.5:1 compression reving at like 9500rpms.....i need a block guard and a block girdle?....what does a block girdle actually do...i never used one of those so i have no experience with them?
Old Aug 25, 2004 | 11:19 AM
X-Mazda 3 Racer's Avatar
We have both the block guard and the block girdle in stock for your application.
The block girdle adds some extra support to the center 3 mains which are seperate in the B20, LS and B16. The GSR has a factory main girdle. Our Main girdle replicates the factory girdle but can be used on the B20, B16 and LS ( B18A, B18B ) We have a full kit to convert you over that includes the oil pickup, longer main bolts, baffle pan and oil pan.
The block guard will aid against sleeve walking that can cause premature headgasket failure. They do not add a whole bunch of strength to the block, but they can certainly help.
If you need anything for your set-up, feel free to give us a call anytime
Golden Eagle Mfg.
Old Aug 25, 2004 | 11:55 AM
CRXEE8's Avatar
Default Re: (GoldenEagleMfg.com)
I'm using a B20B block bored to 85 mm. on stock sleeves. I have 7000 miles on the engine with no problem. I'm at 11.8:1 and rev to 8k.
Old Aug 25, 2004 | 12:41 PM
supanatural's Avatar
Default Re: (CRXEE8)
84.5 is fine on a b20 sleeve, my old motor reved up to 9000 rpms, daily no crank girlde. Just watch for denotation
Old Aug 25, 2004 | 04:12 PM
CRVTEC0WNZJ00's Avatar
Default Re: (supanatural)
Hell thanks for clearing that up somewhat, from what I read on the old b20vtec.com B20 sleeves were trash and cracked alot. But my set up is a B20Z block bored out to 84.5mm hot tanked, honed, Zyglowed block, magnafluxed crank, balanced crank, all new OEM bearings etc. So I'm assuming it will be fine running JE 12:5:1 c/r pistons, eagle rods, engine isn't back yet from the builder but should be back soon, but my transmission and other vital parts are tied up in legal BS work through this shop I had the engine built through and the shop is going under so needless to say I'm pissed I'll put up pics one day when it gets back, I go to court on September 13th to try and get my trans and stuff back, and hopefully $6000.
Old Aug 25, 2004 | 04:18 PM
chad's Avatar
Moderator
I have done 84.5 bore on 3 b20's with no problems....
am going to go 85 soon.....ON STOCK SLEEVES....
Old Aug 26, 2004 | 08:03 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GoldenEagleMfg.com &raquo;</TD></TR><TR><TD CLASS="quote">We have both the block guard and the block girdle in stock for your application.
Golden Eagle Mfg.</TD></TR></TABLE>
email sent
Old Aug 27, 2004 | 06:19 AM
no reply
Old Aug 29, 2004 | 04:23 PM
IntegraB18's Avatar
bump
Old Aug 29, 2004 | 08:14 PM
Default Re: (IntegraB18)
Sorry, our parts manager has been out. Give us a call on Mon. or drop me an e-mail directly at Vince@goldeneaglemfg.com. Sorry for the delay!
blackeg
Aug 9, 2008 03:06 PM
rjc89sir
Mar 9, 2008 10:15 PM
LvN
10
Aug 7, 2006 01:23 AM
Spence
Feb 6, 2004 08:20 PM
advanracing62
105
Jan 20, 2004 04:02 PM
