trans ?
ok i need a new tranny. asap. i blew mine out of my 90 si. i need to know how many teeth there are on the trans. my trans is the orginal 90 si trans. my motor is out of a 98 civic ex a d16y8. i need to know how many whats the tooth count.. can any one help me out?
thanks
thanks
does an one know?? i need to know the tooth count on the clutch
is it 21 or 20
i heard the 88 and prior are when they change, but i dont what they changed to
thanks
is it 21 or 20
thanks
thank you. now will 89 work with 90s since the spline is the same, but the clutches are a diffrent size. also anyone know of a good place to get another si trans or have one rebuilt
if you have original 90 transmission, you can use any 89-91 transmission - the 88 had 21 spline input shaft and 89-91 had 20 spline - the spline count is the only thing that matters, as it needs to match the clutch disc splines
90civic1.5
31
Jan 9, 2011 11:48 PM
89SiB16a
Oct 30, 2002 04:02 PM
