who here runs nitrous?
Old Dec 3, 2001 | 11:34 AM
redteg1's Avatar
Default who here runs nitrous?
wat are your thoughts? recommendations on wat kits to get? AIM sn's would be helpful. o btw...95 gsr stock internals...looking for 13's on juice safely.
Old Dec 3, 2001 | 12:16 PM
vtecvoodoo's Avatar
Future Texas Boy
Default Re: who here runs nitrous? (redteg1)
go direct port or go home
Everybody is going to say "zex". It`s a good kit.
Before you squeze, perform a comp check and leakdown. Your motor could be hurtin already and the NOS would finish it.
Ryan
Old Dec 3, 2001 | 12:30 PM
BoM's Avatar
BoM
Default Re: who here runs nitrous? (vtecvoodoo)
do u want my kit roger? that and a pair of slicks and u'll kill flipspeeds fastest
Old Dec 3, 2001 | 12:38 PM
Vtec integra's Avatar
75 shot plate system will get you in the 13's
its just the same as direct port
Old Dec 3, 2001 | 01:22 PM
B18C-EJ1
Guest
Posts: n/a
Ryan
I gotta agree with Ryan on this one. Direct port is the best way if your engine can handle it.
That plate system from NOS sucks, just spend the extra $$ and get the 4 fogger system.
Oh, almost forgot. GSR's are comfortable with 80HP jets, but with some tuning you could run 120HP jets without a problem.
Lata.
Old Dec 3, 2001 | 02:45 PM
BoM's Avatar
BoM
Default Re: who here runs nitrous? (B18C-EJ1)
Lata.
now thats a big shot!
also u need a new clutch
Old Dec 3, 2001 | 02:52 PM
vtecvoodoo's Avatar
Future Texas Boy
Default Re: who here runs nitrous? (BoM)
I ran a 100 shot for a year on a stock bottom end. It was fast as hell with only $1,000 invested, total!
Old Dec 3, 2001 | 03:16 PM
B18C-EJ1
Guest
Posts: n/a
Lata.
Nah, a 200 shot is a big shot, but I don't recommend it unless you're majorly built.
Old Dec 3, 2001 | 04:18 PM
maxxdout's Avatar
anyone using stock clutch and with what results???
Old Dec 3, 2001 | 06:37 PM
redteg1's Avatar
Lata.
why does the plate system "suck"??
Old Dec 3, 2001 | 09:19 PM
there's nothing wrong with the nos plate system
just if you decide to get a skunk intake manifold or other intake manifold
you can't use the plate. you can buy the nozzles for the direct port though
stock clutch is fine for a 80 shot
should last for a season
Old Dec 3, 2001 | 10:18 PM
H23 Power's Avatar
Default Re: who here runs nitrous? (Vtec integra)
haha, stock clutch went after 3 bottles on 55 shot, 5 runs on 75, actually it still drives, just slips BAD
had the zex kit, it was alright, i would go with direct port if i had to do it again
13.9 with 55 shot intake and drag radials
[Modified by 01GSR, 7:19 AM 12/4/2001]
Old Dec 3, 2001 | 11:41 PM
B18C-EJ1
Guest
Posts: n/a
The plate system is similar to a dry shot in the fact that you install 2 jets. One for fuel and one for N20. The cylinder closest to the jets, gets the most amount of whatever side it's on. The farthest away gets the least amount.
See how the nos comes in one side and the fuel on the other? IMHO the 4 fogger or direct port system is 100x better, and much more controlable.
And there you have it.
[Modified by B18C-EJ1, 12:43 AM 12/4/2001]
Old Dec 4, 2001 | 12:47 AM
Variance-EJ-6's Avatar
New User
I spray on my G2 integra, RS 1997 B18B motor, been runnin a Direct Port 80 shot, with Valve train Upgraded, (SS valves of course) Stock Rods Pistons, etc....
Been good to me, you gotta be responsible with it, If you don't know how to use it, start with 50 shot ZEX kit, cause its safer for all you NEWBIES.....
Old Dec 4, 2001 | 07:49 AM
maxxdout's Avatar
Default Re: who here runs nitrous? (Variance-EG-6)
so i should plan on budgeting for a new clutch if i want to install nitrous?
Old Dec 4, 2001 | 07:58 AM
mr2's Avatar
mr2
Default Re: who here runs nitrous? (maxxdout)
makes me wanna get n2o..
Old Dec 4, 2001 | 08:59 AM
vtecvoodoo's Avatar
Future Texas Boy
Default Re: who here runs nitrous? (white eg)
I don`t like the plate system either.
Old Dec 4, 2001 | 05:54 PM
New User
Direct Port is the way to go....nothing else, the wet system Direct port, the dry system is sorta lame if you don't know how to work it...
And definately get a new clutch, your stock one will burn out depending on how much you are sprayin.....
apexiintegra
Apr 17, 2004 11:21 AM
PreludePhill
Jan 28, 2004 10:19 PM
bottlefedb18c1
Jun 2, 2003 08:17 AM
1.8EG-T
May 20, 2003 12:09 PM
redteg1
Dec 10, 2001 01:16 PM
