TPS problems
Old Aug 21, 2004 | 09:53 PM
DOHC_EF's Avatar
Default TPS problems
I have just done a DOHC ZC swap into my standard 91 CRX. I'm throwing a code 7, which is tps I measue the voltage it reads 4.5-ish volts at idle than .5-ish volts at wide open throttle. The opposite of what its supposed to. So I switch the wires like I'm supposed to and the car runs very bad bogging at open and closed throttle lower and higher RPM. But when I switch the wires back to the orginal positions when it read 4.5 volts @ idle and after the engine is cold it boggs at light and heavy throttle @ 2000 rpms and lower and runs strong otherwise. So what could possibly be the problem? Should I just ignore it if its running fine?
Old Aug 21, 2004 | 09:57 PM
thumbtack's Avatar
Default Re: TPS problems (Caramel)
My d16z6 did that when I swapped my crx dx's engine out.... did you clear the ecu after you switched the wires around... if not pull the negitive (-) battery cable off for about 10 sec... then put it back on, see if that helps.
Old Aug 22, 2004 | 10:16 AM
DOHC_EF's Avatar
Default Re: TPS problems (thumbtack)
Okay will try it this afternoon.
Old Aug 22, 2004 | 04:02 PM
DOHC_EF's Avatar
I switched the wires like I should have but it still boggs like crazy under 2000 rpms on light throttle and when I give it heavy throttle under 2000 rpms its doesn't bogg. Could it be related to fuel pressure? Or timing? Or what? Please help.
Old Aug 22, 2004 | 10:53 PM
thumbtack's Avatar
Timing could have slipped.... I dont know how to check timing for the DOHC... I run a SOHC
Old Aug 23, 2004 | 08:49 AM
DOHC_EF's Avatar
I have tried advancing the ignition timing and retarding it neither work for me it seems like. I'll take it out and it will run fine down the block. But as soon as a drive a little farther it will start to bogg on me under 2000 rpms. Could anything else be a factor?
UnknownKid
Jan 13, 2011 08:07 PM
ChrisHinds
17
Oct 2, 2009 08:46 PM
trecool44
Nov 9, 2008 03:07 PM
DOHC_EF
Aug 26, 2004 05:27 PM
realblag
Aug 6, 2003 05:21 PM
