Z6 Motor
I can right now buy a z6 motor........for 400$ with mpfi...i have a 89 CRX Dx with the crappy 1.5 with dpfi....should i do this??? if so what do i need and also is there ANYWHERE where it describes how to do it..i have all the resources (engine lift...etc) but now do i need the ECU i dunno what i need...please help if u can...also if you live in NY i could very much use your help thanks!!
Greg,
Hilton,Ny
Greg,
Hilton,Ny
you will need the ecu and much more.
1 the motor complete make sure it has the distributor and all of the sensors.
2 talk to blown90hatch tell him you need a obd0 to obd1 harness
3 once you have that you need to convert to to multi point fuel injection
4 you will need to wire vtec in
5 you need to put your drivres side mount on the z6 block
6you use your exsisting tranny because you can't use a 92 - 95
7 that about covers it the rest is minor stuff
I just finished this swap and am running a p28 ecu out of a del sol si. I bought a ecu/wiring harness conversion kit from http://www.locashracing.com
if you are using the z6 distributor, make sure when you do your mpfi conversion, follow the wiring harness convertor's instructions for wiring up the distributor. I did it the obd0 way and it didnt work at all. After I re-read the ecu conversion instructions I realized I wired it up all wrong.
Now it runs like a champ and is alot faster than the d15b2.
CRXguy_88
11
Mar 1, 2010 03:47 AM
phoQ
Mar 27, 2005 12:18 PM
