Cometic 0.120" Head Gasket!
We just got the largest Cometic Headgasket available by cometic (they just released it!). It's supposed to drop your compression on your GSR by about 2 POINTS!
Cometic 0.120" Head Gasket. This thing is super thick! Perfect for your Turbo application.
I also picked up some ARP Head Studs and a Race Engineering Block Guard.
The guy's at Cometic shipped us this Prototype Head Gasket and told us they've been running this Head Gasket and block guards on their Turbo GSR with stock block at 14lbs all day everyday without no problems.
Should put the compression lower than an Integra LS and still retain Vtec.
A couple more things, then the GSR should be boosted.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B00ST2nR »</TD></TR><TR><TD CLASS="quote">
That is a expensive gasket and it might cause you timing belt issues...and btw,lots of guys have ran stock headgasket GSRs @14psi with no problems,its all in the tune
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by i want a civic »</TD></TR><TR><TD CLASS="quote">Is this gasket available on the prostreet website?!?!</TD></TR></TABLE>
It's not. It's a special order and we can get get them for $199.99. Takes about a week or so.
It puts the Compression Ratio down to like a DSM. I wouldn't have to worry about blowing a head gasket with this bad boy.
its been avail on the raceeng site for a year or two for $175--->http://www.raceeng.com/showIte...19579
A gasket that thick will definitely throw the timing off, I know of people running the .90 that have had to do cam gear adjustments after the install.
This is still the cheapest way of lowing the compression and making great power so I support the idea.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by earl »</TD></TR><TR><TD CLASS="quote">1 degree for every .012" of change from stock.</TD></TR></TABLE>
VERY informative as usual :D thx.
BTW, that .120" gasket has been around for a long time. I've seen it for as little as $100</TD></TR></TABLE>
WOW really let me know where i can get them for that much or do you sell them!?!?...Pm me to let em knwo thanx..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cole D »</TD></TR><TR><TD CLASS="quote">What's the disadvantages to running a headgasket that thick ????? The part number on that HG is CM-H1345120S</TD></TR></TABLE>
It drops the compression on a GSR from 10:1 to 8.2:1
Great info
Great info
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beepy »</TD></TR><TR><TD CLASS="quote">Damn. That must ruin quench.</TD></TR></TABLE>
Yup....thats why alot of teh thick headgakset setups that you see making good power for stock blocks are on race gas
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tchleung »</TD></TR><TR><TD CLASS="quote">hey earl I forgot to ask, would that be 1 degree timing advance or retard on both gears for every .012" thicker then stock?</TD></TR></TABLE>
yeah i want know too
WOW really let me know where i can get them for that much or do you sell them!?!?...Pm me to let em knwo thanx..</TD></TR></TABLE> I think I bought it from Dynamic Auto Sports
