Neuspeed Race on 92 Lude which camber kit?
Old Aug 21, 2004 | 07:43 PM
Lude@Heart's Avatar
Default Neuspeed Race on 92 Lude which camber kit?
Hey yall i decided i want the Neuspeed Race cause they look the best:
http://www.imagestation.com/pi...g.jpg
the bottom pic.
Top is stock and middle is comparable to Neuspeed Sports.
But i will deff need a camber kit so which should i get.
thx
Old Aug 21, 2004 | 07:51 PM
TxTuner
Guest
Posts: n/a
Default Re: Neuspeed Race on 92 Lude which camber kit? (Atomfried)
Can't go wrong with ingalls
Old Aug 21, 2004 | 11:29 PM
bad-monkey's Avatar
Default Re: Neuspeed Race on 92 Lude which camber kit? (TxTuner)
SPC front ball jt's are better than the ingalls anchor bolts in the front.
in the rear, either one is ok.
Old Aug 22, 2004 | 12:33 PM
Behan's Avatar
Default Re: Neuspeed Race on 92 Lude which camber kit? (bad-monkey)
go get a 4 wheel alignment after you have installed the springs. Make sure they adjust the toe to specs. Once you have the alignment done you will know what camber kit you need.
They have different degrees of adjustment.
h22a193
May 4, 2005 04:49 AM
dOwNeR
Aug 21, 2004 09:03 PM
sombasol
May 28, 2004 05:05 PM
ce97lude
Mar 25, 2004 08:06 PM
jr_istheman
Jan 3, 2003 04:38 PM
