MY CRX TAIL LIGHTS WONT TURN OFF!!!!!
WHEN I TURN OFF MY CRX THE TAIL LIGHTS WONT TURN OFF
IT SEEMS LIKE SOME ONE IS PUSHING THE BREAK AND WHEN I
DRIVE IT AROUND IT DOES THE SAME THING!!!!!!!!!!!!
PLEASE HELP ME!!!!!!!!!!!!!!!!!!!!
more than likely its a thing called the brakelight sensor..well..thats probably not the technical term..anyways..its a little blue rubber pointy looking thing..it wears out and falls out from the hole it goes into..follow the brake pedal arm under neath the dash..youll see a little hole where the rubber thing used to be..what it does is it pushes on a trigger type sensor..all you need to do is gerry-rig a nut/bolt into that hole so that it pushes in on the trigger sensor..hope this helps
EDIT: if you cant find a nut/bolt to put in that hole..ive seen or heard of people taping pennies or nickles on there to strike the trigger..post up and lemme know if you fixed it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mxler8 »</TD></TR><TR><TD CLASS="quote">THANX A LOT MAN</TD></TR></TABLE>
i take that as a "yes..it worked"??lol..for future reference..theres another similar blue rubber pointy thing for the clutch arm as well that goes to the starter..if you ever have problems starting the car all of a sudden and you see a broken blue rubber thingie on your floorboard..same deal..
yes i found a blue plastic thing in the floor of the car it was all broken off into 5 pieces
tomorrow i am going to buy a new one a AUTOZONE
Modified by mxler8 at 8:03 PM 8/21/2004
