V-AFC or Hondata
Old Dec 3, 2001 | 09:43 AM
ITR #1202's Avatar
Default V-AFC or Hondata
which would be better after I/H/E ?
would the hondata computer do all the same things the V-AFC would do.
Old Dec 3, 2001 | 09:54 AM
Rguy's Avatar
Voted Best Looking GDD Poster
25 Year Member
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: V-AFC or Hondata (ITR #1202)
EVERYONE agrees, hondata craps all over the VAFC. Hondata does more than the VAFC does. www.hondata.com
AWDSOME's Avatar
The Hondata would do everything you need and more, but is a very large investment especially if you are only doing I/H/E.
Here is a post that should help you out.
https://honda-tech.com/zerothread?id=95686
Watch how fast the dollars grow. For the record I am leaning towards the Hondata since I will be doing internal changes to the engine as well (Most likely TODA, but need to do some more research on JUN)
Old Dec 3, 2001 | 09:58 AM
austrian type-R's Avatar
You can´t compare the 2 things. The VAFC let you only change the VTEC engagement point and tune the a/f mixture. The Hondata is a more complex system. You can tune the timing, fuel, Vtec, redline, part and full throttle, fan activating and and and. A dyno is nacessary for both system. Even with the VAFC dyno tuning should be made with an wide band O2 lamda for the best hp numbers. Without dyno tuning you´ll waste your money and the Apexi unit is only for show in your car.
Old Dec 3, 2001 | 11:25 AM
ITR607's Avatar
New User
for the money i would get the v-fac or same some serious $ and get a pac-tel stand alone system thats what im going to get but the cost for that is 5k,but right now i have a v-fac and my car is supercharged and works great as long as you have a good tunner which i do
Old Dec 3, 2001 | 12:00 PM
TypeR0149's Avatar
what would you rather have a hand job from Barbra Bush, or sex with Britney Spears, same thing, go with hondata
93h22a1vtec
Dec 19, 2005 04:25 PM
sleep
15
Feb 11, 2004 03:30 PM
Teal95Coupe
Apr 4, 2003 03:04 PM
dabomb
Mar 11, 2003 04:37 PM
G3gsr
Feb 6, 2003 08:37 AM
