Buying 16x7.5 Advan RG... what offset is on a type r
you will encounter rubbing issues with anything less than a +42 offset depending on how low you car is
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98-0688 »</TD></TR><TR><TD CLASS="quote">the rims i am looking at have a 45mm offset. so that will be fine on the car?</TD></TR></TABLE>
yes
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98-0688 »</TD></TR><TR><TD CLASS="quote">also what size tires would be good for a 16x 7.5 inch rim</TD></TR></TABLE>
205/45/16
215/45/16
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98-0688 »</TD></TR><TR><TD CLASS="quote">215/45/16 azenis fit?</TD></TR></TABLE>
please note, i have owned a set of 215/45/16 azenis b4...they are not a true 215, i measured it and it was closer to 225
yes
205/45/16
215/45/16
That should be fine.
My SSR 15 X 7.5 are +43 (or maybe +45) and there were no problems even when running a bit lower than stock on Buddy Clubs.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zygspeed »</TD></TR><TR><TD CLASS="quote">
My SSR 15 X 7.5 are +43 (or maybe +45) and there were no problems even when running a bit lower than stock on Buddy Clubs.</TD></TR></TABLE>
the 15x7.5 SSRs are +43
I have the 16*7.5 +45 offset Advan RG's with 215/45-16 azenis with buddy club suspension on my car. The only place that I rub on my car is the front put only at full lock (so just don't full lock
On a stock ride height the tires will not rub.
I try to post some pics later. We-todds site is down.
)On a stock ride height the tires will not rub.
Aug 24, 2004 03:20 PM
