Smog Check... (GASP)
Old Aug 21, 2004 | 09:23 AM
Milky's Avatar
Default Smog Check... (GASP)
For all you crx LS owners out there that had their smog checks... did u guys pass??? and i mean pass as in... going to a smog only certified station.. no mechanics that would let u slide... did u guys pass??? let me know asap... Would an ls motor with b16 tranny pass smog?? haha.. would they fail u on the spot if they saw that u had another motor for ur crx???
Old Aug 21, 2004 | 11:18 AM
tRex99's Avatar
Default Re: Smog Check... (Milky)
Well im guessing you live in cali? ANYWAY the tranny has nothing to do with it so dont worry about that. People get ls rexes passed all the time they just have trouble passing vtec rexs. Just make sure its clean looking under the hood, get a vaccum diagram and make sure everything is perfect and easy to find. As long as the motor is newer then ur car so 90-95 then ur good to go. Its easier to pass a 90-91 motor because its obd0 but the obd1 will pass and obd2 i think i read about 1 that has passed. Alot has to do with the tech you get too just clean it up make it nice and run perfect and be a kiss ***...I have an ls rex too i just havent take it to the smog refs either. If i wasnt a poor little bastard then i could buy everything i think needs to be replaced....
Old Aug 21, 2004 | 12:34 PM
Milky's Avatar
Default Re: Smog Check... (tRex99)
what about if theres a cam job.. cuz this crx has after market cams with cam gears... it also has headers... and its a b18b... one of the newer ls motors with about 50k on it..... and yea.. i'm from cali..
Old Aug 21, 2004 | 04:10 PM
NinjaOfSRO's Avatar
if you want to pass it get it reffed. stage 1 cams usually pass smog with no problem (usually). any aftermarket bolt ons should be made for that motor and be carb legal. and make sure all vacuum lines and sensors and smog equipment are properly hooked up.
its really not that hard to get a swap to pass reff tech... the only ones who have to worry are the people who ghetto rigged the swap or are running something illegal like a ZC or LSvtec.
Peruviann
Dec 4, 2007 04:59 PM
DC4 me
Dec 2, 2006 10:48 PM
alain pestanas
Jan 28, 2005 11:30 AM
oh-k
Aug 7, 2004 10:19 AM
garrulous thief
Aug 18, 2003 12:45 AM
