Buzz from indiglo gauges...
Old Aug 20, 2004 | 09:50 PM
ItalynStylion's Avatar
Default Buzz from indiglo gauges...
Ok, i have some blue indiglo gauges for my 5th gen.
I noticed that when i have them on(lit up) and the stereo on they make a high pitched buzz, like on an indiglo watch.
With the stereo off the noise doesn't occur.
Having the head unit on even if its muted causes them to make this noise.
What gives? How do i fix it?
Old Aug 20, 2004 | 09:52 PM
lancer's Avatar
Default Re: Buzz from indiglo gauges... (ItalynStylion)
which wire did you splice into to hook up the indiglos?
Old Aug 20, 2004 | 09:58 PM
Default Re: Buzz from indiglo gauges... (lancer)
i ran a power wire to the right headlight fuse so that the gauges come on when i turn on the lights
Old Aug 20, 2004 | 11:51 PM
ScareyH22A's Avatar
Honda-Tech Gold Member
Community Builder
I don't think the stereo is making the indiglo buzz... but probably the other way around. The indiglo is making your stereo buzz. You probably have amps hooked up to your interior speakers and the high current indiglo module is emitting EMI to the RCA cables leading to your amp.
See if your RCA cables are running under the driver's side dash. If so, you may need to relocate the indiglo module higher in the dash and towards the driver's side a-pillar.
Old Aug 20, 2004 | 11:52 PM
Nikoli's Avatar
please stop... get out, shew :sprays insect repellent:
Old Aug 21, 2004 | 12:28 AM
andeh22's Avatar
yeah, its youre wiring. who did the wiring?
for me, when i turn on my head unit, its a quiet whirring/buzzing noise.
but when i turn on my hids or ac up, it gets louder and increases with rpm. 'engine noise' or something like that.
maybe wrong tho.
Old Aug 21, 2004 | 06:43 AM
Default Re: Buzz from indiglo gauges... (andeh22)
you got it man, i forgot to say it increases with rmp...
But in answer to the other guys i ran all my wiring and the rca's are on the other side of the car.
Old Aug 21, 2004 | 11:36 AM
ScareyH22A's Avatar
Community Builder
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ItalynStylion &raquo;</TD></TR><TR><TD CLASS="quote">you got it man, i forgot to say it increases with rmp...
But in answer to the other guys i ran all my wiring and the rca's are on the other side of the car.</TD></TR></TABLE>
Then, it would happen even if you didn't have indiglos. Check and make sure you didn't run the power cable to the amp next to the RCAs.
Old Aug 21, 2004 | 09:15 PM
Default Re: Buzz from indiglo gauges... (ScareyH22A)
I did run the power caple next to the RCA's, but the noise only occurs when the gauges are on...
when the lights are on. So its not just the stereo its a combination of the two
Old Aug 23, 2004 | 09:23 AM
ScareyH22A's Avatar
Community Builder
Relocate the RCAs to the other side of the car and the noise will go away. That's a 'Textbook' Mickey Mouse amp install.
Old Aug 23, 2004 | 09:26 AM
Pr0jektLude's Avatar
my indiglos make a buzz noise too but its when the car is turned off its like a setting...the higher the noise is, the brighter the indiglos get...its liek a warning noise or something. I dunno maybe thats what your hearing.
Old Aug 23, 2004 | 09:27 AM
killa_lude's Avatar
agreed.
Old Aug 23, 2004 | 09:47 AM
98TypeSH's Avatar
Default Re: Buzz from indiglo gauges... (killa_lude)
has to do with the RCA cables, i had the same problem till i guted my trunk. Also make sure the metal RCA connectors arent touching any type of metal behind the head unit as this will cause weird noises and feedback to come out of your subs/speakers.
Old Aug 23, 2004 | 10:20 AM
Default Re: Buzz from indiglo gauges... (98TypeSH)
Thanks guys, ill check all of that.
DuniCraig
Audio / Security / Video
Aug 11, 2008 01:09 AM
thrty8street
Feb 14, 2008 11:48 AM
Shakes
Aug 29, 2004 09:45 PM
sol2nr
Aug 4, 2004 09:23 AM
IVI
Apr 25, 2004 11:14 AM
